5ag was using HKS stroker crank which was 83.00mm stroke compared to 77.00mm stroke
capacity with recommended 81.00mm HKS piston(which was a must as the gudgeon pin height is different) was 1710cc
Use of HKS crank needed the block ground away to handle the extra material on the crank webs
