bump, will be out tomorrow.
Pulling the bigport 16v 4AGE out to make way for the 4AGZE, will need this gone ASAP once it is out (should be out early next week)
At the moment it will just be engine, cut and shut plenum, ECU, loom (may be cut, unsure of previous owners wiring)
Water piping etc may or may not come with it depending what I need for the GZE. May or may not come with airbox and K&N filter.
Will not have flywheel/clutch.
Engine is a bit tappety (just need adjusting), and has a small leak (guessing the main engine seal) still goes hard.
I have 2 spare ECU's, an old dizzy, igniter, coil whatever else spare that can't be used for the GZE.
Pick up only BEERWAH 4519, no postage. THIS IS AN ENGINE ONLY DEAL, don't ASK FOR MOUNTS, BOX , EXTRACTORS ETC
$600 ONO or swaps for KE70 related things of interest.
PM me yo.
SOLD!
What airbox is that you used?
VN, modified.
Hi mate it says you have 2 spare ecu's in the post.are they bigport?how much are you chasing for 1 of them. cheers
