Genuine new Toyota parts
unless otherwise stated
- Private message
- Post in this thread
- call: 0421 010 890 (10am to 10pm in Victoria)
Almost all parts kept on the shelf in Victoria, is if it's urgent call
Other parts not in this list can potentially be ordered, just ask.
Prices subect to change.
GST inclusive.
4age 20V universal
- Dizzy cap: $80
- Rotor Button (Bosch): 30
- TRD Head gasket: $120
- OEM head gasket: $80
- Front top water outlet gasket: $9
- Intake and exhaust seals: $15 each
- Valve stem seals: $95 (set of 20)
- Cam cover seal: $30
- VVT Solenoid: 70
- Flywheel bolts: $2 each
- Head bolts (no washers): $13 each
- Accessory belt: $45
- Accessory belt pulley: $110 (water pump and alternator)
- RWD water pump: $110 (for some converted engines, complete front and housing)
- Spigot bearings: $8 Nachi or NSK
20V Silvertop parts
- Gasket and seal kit: $295
- Exhaust gasket: $25
- Intake gasket: $60
- Timing belt: $55
- Timing belt: $35 (Gates)
- Timing belt pulley: $55
- Timing belt pulley spring: $8
- Cam belt drive pulley: $22
- Crank pulley: $230
- VVT pulley: $290
- Water pump: $110 (complete front and housing)
- Pistons +0.5mm: $45 each
- Piston rings +0.5mm: $110 set of 4
- Oil pump: $170
- Oil pump ported: $220
- TPS: $110
20V Blacktop parts
- Gasket and seal kit: $280
- Throttle body gasket: $20 set of 4
- Timing belt: $55
- Hydraulic belt tensioner: $80
- Complete belt kit with the above: $180
- Cam belt drive pulley: $26
- Crank pulley: $210
- VVT pulley: $260
- Pistons +0.5mm: $48 each
- Oil pump: $170
- TPS: $110
