Results 1 to 6 of 6
Thread: Low end problem
    Member jy086's Avatar
    Nunawading
    Default Low end problem
    hi guys....i got a 4Age smallport with Ae101 quads, around 264 cams, cam gears, springs....o/s pistons 0.8mm HG.......and so on
    i just got it tune...running e-manage.....
    i can't put my foot down until it rev past 3000rpm....it just bogs.....anyone with similar problem?
    it rev's very hard and fas when past 3000rpm
    gay
    n1gger land
    n1gger land
    south korea seoul
    was TPS touched ?? could be TPS setting ?
    Nunawading
    what can you change on the TPS???
    Reeece
    Casula
    if you position it incorrect or it could be faulty.. Sounds like tps or timing to me
    Nunawading
    Thanks for you info....how can you tell if it's faulty?
    Back Once Again
    disconnect the sensor plug
    insert a feeler guage between the throttle stop screw and stop lever
    using an ohmmeter, measure the resistance between each terminal
    looking at the tps plug hole, the terminals are as follows, going in decending order
    E2
    IDL
    VTA
    VCC
    the following is stock settings
    gap between lever nd stop screw | between terminal | Resistance (ohms)
    0.............................................| VTA - E2.............| 200 - 800
    0.35........................................| IDL - E2..............| 2,300 or less
    0.59........................................| IDL - E2..............| infinity
    Throttle fully OPEN.....................| VTA - E2............| 3,300 - 10,000
    ^^gap measurements in mm^^
  1. Replies: 12
    Last Post: 11th January 2012, 11:25 AM
  2. Low RPM minor Surge problem..
    By 4agejet in forum Melbourne & Vic Events and Discussion
    Last Post: 22nd February 2011, 07:17 PM
  3. WTB ke70/ae86/ae71 tube things between rack end and tie rod end
    By ke70dave in forum Cars or Parts Wanted
    Last Post: 25th June 2010, 06:01 PM
  4. AE101 '92 Toyota Levin - LOW LOW kms - Clean - 5sp - VANCOUVER
    By lchazl in forum Cars for Sale (Toyota Only)
    Last Post: 30th July 2009, 08:23 AM
  5. 4agze Problem at low rpm boost
    By DavisJD in forum Technical - Questions
    Last Post: 22nd March 2006, 09:43 PM
