Have you got any photos of the porting by any chance!
Hey Guys
I have a small port head off my spare motor up for sale.
Head did 500kms on an engine and the engine was stripped to do more work. Heads in great shape and has mild port work, water jacket areas are perfect and fire deck is good. Comes with Toda HD valves springs and is fitted with a shim less bucket conversion. A few of the buckets looked a little average so I have 10 new buckets still in the packets.
I'm looking for $500 for the head without the shim less buckets or $750 with the buckets. If the head sells without the buckets I will sell the for $300 on there own. Head has had the springs etc removed for inspection but will be reassembled when purchased.
Looking for local pickup in Perth or will assist with shipping. I will post pics later tonight or can send pics to interested parties.
Last edited by Prime86; 2nd September 2013 at 11:36 PM. Reason: Picss of water jacket area added
Pic's added mate
Port work was only minor on this head to match port the quad throttle body adaptor to the head and a bit around the valve seats.
I will have the complete intake system up for sale too that is a very nice setup. T3 adaptor, silvertop throttles, TWM 65mm volocity stacks all with stainless fastners.
Heres a pic of the spare engine with the head and intake.
$600 takes the head with shim less bucket conversion as is.
Hi mate I'm pretty keen on the head just working out whether it's worth getting the shim-less buckets as well, I'm running stock smallport ECU and intake so maybe my revs would never be high enough to need them???
The head is setup with the shim less buckets already. It's fine to run shim less buckets with stock everything if you want it just means your able to put big cams and big RPM through the motor if you want.
OK so for the $600 I would have a head I can put my standard cams into and have correct valve clearances ready to go straight onto my block after it gets back from the engine builder?![]()
For $600 you would have a complete head yes but I have the springs etc out of it at the moment. Valves buckets etc are in the head in the correct positions so just have to put the springs in and go. All springs collets are in bags clearly labeled ready to go back in.
Hi Prime86, Im Neil from New Zealand. Would you be interested in shipping your head to New Zealand? Would you also consider selling the Head complete with shimless buckets, Toda Valve Springs. T3 Manifold adaptor, ITB's, Trumpets? Would you have a price in mind for the complete setup? Cheers Neil.
Yeah woul be willing to post at buyers expense. Intake has been sold already sorry Neil.
