Results 11 to 11 of 11
Thread: AE93 Smallport 4age w/ minor mods.
Threaded View
    Veteran slide86's Avatar
    Huw
    Hills
    Default AE93 Smallport 4age w/ minor mods.
    I have acquired another car that was an absolute bargain, so regrettably I need to move this on.
    I have owned the car for approx 12 months, in that time it has only been on the road for 9 months. During that time I have only driven it every fortnight for 600km highway round trip. I work FIFO, so I only use the car to get to the airport and home (which is country SA).
    Car is a Series 1 AE93 SX Twin cam. Has a VERY HEALTHY smallport 4age. Current odometer reads 335*** but does not reflect the mechanical condition of the vehicle, read below.
    During the 12 months I have owned the car I have repaired or replaced the following:
    Full service inc oil, filter, plugs, air and fuel filters (every 5000kms)
    New rotor button
    New Dizzy cap
    New OEM cam seals
    New OEM cam belt
    New OEM cam belt tensioner spring
    New OEM cam belt pulley
    New water pump
    New drive belt
    New A/C belt
    New Thermostat
    New Koyo radiator
    New lower radiator hose
    New lower ball joints
    New tie rod ends
    New KYB front shocks
    New front discs and pads with series 2 front calipers (larger rotor/brake combo)
    New rear discs and pads
    Base idle rest
    Upper engine cleaner to clean valves, inlet manifold
    Genie extractors
    De-cat pipe (OEM cat included)
    4 brand new tyres
    CD player with AUX input
    I have replaced most of the cracked or damaged interior trim pieces, or pieces that were missing when i purchased the car. Interior is in reasonable condition for age of vehicle. I fitted floor mats to keep carpet reasonable, no one ever sits in back.
    Bad points:
    - The body is ok for the age, but has a dent around the fuel flap and one in the RHF guard. Both of these were like that when i bought the car. I have a replacement front guard that needs paint. Both front and rear bumpers need paint as its peeling off. I can supply pressure pack paint in correct colour code.
    - Oil pressure gauge in dash does not work, needs a new cluster to replace ($60). I have tested the engine oil pressure with a gauge, pressure is still excellent with over 50psi.
    - Spare wheel well has some rust in it, as the tail lights were leaking water before I purchased.
    Car is located in Adelaide SA, I am away alot for work, so inspection and purchase times need to be made in advance.
    This is a very reliable car with still good power to boot.
  1. Michael's AE93 Smallport 4AGE Seca SX (Sydney)
    By Babyhunts in forum Other Toyotas
    Last Post: 5th September 2013, 08:02 PM
  2. Black EVO VI With minor mods
    By 44GTE in forum Cars for Sale (Not Toyotas)
    Last Post: 12th July 2012, 11:36 PM
  3. Nissan 180sx Type X Low K's, Minor Mods (SA)
    By Dave in forum Cars for Sale (Not Toyotas)
    Last Post: 18th June 2012, 02:09 PM
  4. QLD ae86 $4000 ono minor mods
    By ke-matt in forum Cars for Sale (Toyota Only)
    Last Post: 18th September 2011, 08:20 PM
  5. ae93 smallport 4age for sale. (vic)
    By resol in forum Car Parts For Sale
    Last Post: 25th July 2009, 10:39 PM
