Page 40 of 55 FirstFirst ... 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 ... LastLast
Results 391 to 400 of 543
Thread: Drift Fest Zero 3
  1. #391
    I need to know ASAP who is camping friday night
  2. #392
    Jake
    Northgate
    Stupid fucking brakes still won't bleed properly! other than them I'm pretty much set other than a wheel alignment and couple of other little things but these brakes are doing my head in
  3. #393
    Gone
    Joel
    Picton
    What car and what brakes?
  4. #394
    Gone
    Joel
    Picton
    Keep an eye out here for the DF03 weather forecast
    be sure to pack some gummies and a rain jacket
  5. #395
    Jake
    Northgate
    My 1UZ T18, running a wilwood floor type pedal box so all the master cylinders are inside the car now. Remade all the brake lines last weekend, front brakes bleed up fine rears won't tried pressure bleeding using my vacumm bleeder and compressor tried bleeding with two people tried just about everything resulted in a dented guard now which was stupid of me because T18 guards aren't the easiest thing to find :/
  6. #396
    Jake
    Northgate
    The brakes will be the only thing that will stop me from driving and if it's not ready not driving all the way waste diesel to not run. I can run just the front brakes as it has seperate master cylinders inside the car though if that would be ok?
    Running MA70 supra rear brakes on hilux diff with a hydro handbrake inline with rear brakes thinking of taking it out and seeing what happens.
  7. #397
    Gone
    Joel
    Picton
    you need to bleed the lines, longest to shortest, so typically, rear left, rear right, front left then front right, then bleed the masters.
    Though, you might want to bench bleed the masters before you install them.
  8. #398
    Junior Member 180onTapp's Avatar
    Nov 2012
    Andrew
    Peakhurst
    Camping Friday night.
    To do:
    Oil change, finish fitting extinguisher. Easy.
    Just because someone goes fast doesn't mean you should do whatever you think they did. This path assumes they knew what they were doing, which isn't necessarily the case. Take this path and you will be guaranteed second place.
  9. #399
    Nov 2012
    Andrew
    Peakhurst
    I've got a spare seat, coming from Peakhurst. I will be meeting up at Maccas.
  10. #400
    Veteran drift kid's Avatar
    Glossodia
    Don't forget to bleed the handbrake too, that's what was stuffing me with my inline setup
  1. Drift Fest Zero 2
    By sundee in forum Official AE86 Driving Club Meets and Events
    Last Post: 21st August 2013, 10:26 AM
  2. Drift Fest 01, Raleigh int Raceway
    Last Post: 14th December 2012, 01:37 AM
  3. toy fest 2010
    By motorculture in forum Youtube Chan
    Last Post: 17th January 2011, 10:10 PM
  4. toyota fest '10'
    By 70rolla in forum Sydney & NSW Events and Discussion
    Last Post: 5th October 2010, 01:41 PM
  5. Toyota fest 09
    By AEA-386 in forum Sydney & NSW Events and Discussion
    Last Post: 23rd September 2009, 06:13 PM
