I have for sale 2 ae86 sprinters. First one is an immaculate rolling shell with full cage , sainz bars etc. , painted inside and out in white. All panels and interior are in mint condition. just got sill stands fitted and extra bars put in by Eddie at Penrith city exhausts. The car is a bare rolling caged shell , it has a steering wheel and that's it. For this car I have a fresh 3sge beams engine and gearbox with custom heavy duty mounts to suit dropping the beams into the ae86 engine bay. I also have some smick carbon parts , a ultra lightweight carbon dash , carbon door cards , nav foot rest and a set of front and rear arch flares. A fibreglass light pod is also with this car along with carbon aero bonnet clips. The second car has the following .
Car has NSW road rego that expires on 21/12/2013
4AGE bigport with quad throttle bodies
Wolf ECU with hand held controller
Custom 2 ¼” exhaust
Heavy Duty Exedy clutch
Fresh W55 just been stripped and checked and all new bearings put in
RA40 hubs on Bilstein adjustable suspension
Custom switch panel with kill switch, isolator switch , fuel pumps on/off
Race approved fire extinguishers x 2
Bilstein rear inserts
Adjustable ride height
Toyota Hilux rear axl with 4.8
15” wheels
Terratrip 202 plus rally trip meter ($325 new)
Terraphone professional plus intercom ($365 new)
Fiberglass light pod (no lights)
CDS full weld in cage 38mm ront legs , 44mm main hoop, 2.8mm wall
Front quad piston landcruiser brakes
Rear brakes EA Falcon
All lines braided
Twin Bosch fuel pumps
Custom 100l fuel tank
Hydraulic handbrake
Whiteline sway bar
Nolethane and Noltex bushes throughout
Bosch alternator (Huge)
Adjustable fuel regulator
custom sump guard
spare bonnet
2 sets front and rear lights
Bad points:
I'm keeping my race seat so there will be no seats sold with the car
Spot of rust on boot door
Bubble of rust around bonnet pin on drivers side
Front bumper has been cut to slide in a light bar , the car now has a fiberglass light pod.
Hole in the roof where 2 way radio antenna sits
So I was going to transplant parts from the blue car and make a really good white car, but true to form I've changed my mind and am doing something different. I want to sell everything as one package and at this stage will not separate any of the parts. The blue car is running and has rego . The only issue with this car is the fuel tank , the standard fuel tank need to be put back in so it can get a logbook or you need to somehow separate the tank from the rest of the cabin. Other than that all you need is seats , harness etc and your in the bush.
Ill get more pics up later of the white car
location is Narellan in Sydney . For serious enquiries I can bring 1 of the 2 cars down the south coast to Ulladulla if that's any help to anyone.
Price .... here we go ... I realise I'm going to take a hit on these cars and the parts. The whole lot will cost more than 10k and less than 20k.Do the maths on what you think its worth and make an offer.
Charlie 0415612212
I probably wont answer so text or email and ill get back to you.
