Page 25 of 27 FirstFirst ... 15 16 17 18 19 20 21 22 23 24 25 26 27 LastLast
Results 241 to 250 of 263
Thread: Jarrad's AE86 resto project
    Mar 2013
    andrew
    perth
    looks good man !!
    what hatch is that ? or did you mould a spoiler onto a hatch ?
    Aug 2012
    Jarrad
    east
    Here's a bunch of pics! Go nuts, hahaa.
    Not ashamed to say I'm very happy with the end result. There's a lot a work in that. Sikaflex and rivets to hold it down. Then mostly fibreglassed and a bit of filler to get it perfect. It came out very well and looks like a one piece moulded part.
ID:	36996Click image for larger version.
ID:	36994Click image for larger version.
ID:	36995Click image for larger version.
ID:	36997Click image for larger version.
ID:	36998Click image for larger version.
ID:	37001Click image for larger version.
ID:	36999Click image for larger version.
ID:	37000Click image for larger version.
ID:	37002Click image for larger version.
ID:	37003Click image for larger version.
ID:	37004Click image for larger version.
ID:	37005Click image for larger version.
ID:	37006Click image for larger version.
ID:	37007Click image for larger version.
ID:	37008Click image for larger version.
ID:	37009Click image for larger version.
ID:	37010Click image for larger version.
ID:	37011Click image for larger version.
ID:	37012Click image for larger version.
ID:	37013Click image for larger version.
ID:	37014Click image for larger version.
ID:	37015Click image for larger version.
ID:	37016Click image for larger version.
ID:	37017Click image for larger version.
ID:	37018Click image for larger version.
    Mar 2013
    andrew
    perth
    well done man ! came out heaps good !!
    whole car looks great.
    Aug 2012
    Jarrad
    east
    Thanks dude! Getting pretty keen now
    Senior Member Brendan's Avatar
    Brendan
    Man I love this thing! Great work dude...
    Mar 2013
    andrew
    perth
    hey man whats your final thoughts on the knox carpet, im thinking of getting some.
    did you get the loop pile ?.
    cheers.
    Aug 2012
    Jarrad
    east
    Hey, yeah. Pretty happy with it. Make sure you get some underfelt though. I had to double that up in the footwells. I got the loop pile. It's closer to OEM.
    I've also fitted plush pile into a Pontiac and it's harder to work with and thicker.
    Aug 2012
    Jarrad
    east
    Wow, bit slack on updates. I dropped my diff off with a replacement 4.1 ratio that turned out to be not good. It wouldn't pattern up in any way, shape or form. Ended up sourcing another so there was a bit of a delay there. But now the diff is in and sounds much better.
ID:	37121Click image for larger version.
ID:	37120Click image for larger version.
    In the meantime, I wanted to make an airbox for my carb set up. But I'm not sure that I will end up using it due to clearance and fitment issues. I may have another go at making it.
    Anyway, for the sake of others and the exercise. I made a guide skeleton from cardboard and MDF, and foamed a urethane based expanding foam into it. Then cut it back to the desired shape. Trust me to believe the cans instructions, it really does expand a lot.
ID:	37108Click image for larger version.
ID:	37109Click image for larger version.
ID:	37110Click image for larger version.
ID:	37111Click image for larger version.
    After cutting it down and test fitting it.
ID:	37113Click image for larger version.
ID:	37114Click image for larger version.
    I think wrapped it in glad wrap so the fibreglass wouldn't stick, and moulded over the top. fitment is generally okay.
ID:	37116Click image for larger version.
ID:	37117Click image for larger version.
    This is a laser-cut base plate I got for mounting/testing purposes and may end up going with something based off this instead.
    Anyway, this is now what's keeping it from running... I wanted to install a speco water temp gauge, as well as keep the dash gauge. The bloody adapter sheared off in the housing! such a pain... So I think I'll just tap it out and put a sensor in without an adapter.
ID:	37124Click image for larger version.
    Aug 2012
    Jarrad
    east
    OK! It's damn near time to close this chapter! May as well finish the book haha.
    I got the diff in, all the water system sorted and sent it to be finished off/tuned at Allcraft Automotive in Moorabbin - as reccommended to me from a few people due to the Mikunis on the car.
    They were fantastic in wanting to get the car RIGHT. Turn key and go!
    He reworked a few things, like the throttle linkages and pedals. My brakes were seized from being rebuild almost 5 years ago. Fuel system was simplified. I had a weird wiring issue with my headlights too.
    Carbs were cleaned, valves were shimmed, cams timed, speedo cable replaced and a few other small things.
    Anyway! Winners are grinners. I had my first real drive of the car. It was such an awesome feeling - so many unknown noises and stuff, but it already feels heaps of fun to drive.
    I am suspicious that the gearbox has straight cut 1st, 2nd and 3rd gears in it. I did buy it from a guy that raced AE86s and it was meant to be rebuilt.. so who knows. It sounds pretty wicked haha.
    I ended up not stuffing around with the airbox and made these air cleaners fit.
    The dyno showed they were a bit restrictive, sapping around 5kw at 7500rpm. I will try shorter velocity stacks inside them.
    The good news is... I made 102rwkw tuned on BP Ultimate 98.
    Here's a short clip taking off/engine noise up hill.
    It's now just finally awaiting RWC/rego when I have the time to organise that.
    Jun 2011
    bazz
    nsw
    sydney
    Looks great mate. Congrats
  1. Jarrad's RA65
    By Jarrad86 in forum Other Toyotas
    Last Post: 12th December 2010, 11:17 AM
  2. Jarrad's RA65
    Last Post: 16th October 2009, 12:09 AM
  3. My Project AE86
    By 4A-GE Power in forum AE86 Owners Forums
    Last Post: 2nd October 2008, 08:13 AM
  4. ADM resto
    By Judge Fudge in forum Cars or Parts Wanted
    Last Post: 14th August 2008, 07:21 PM
  5. Teddy's JDM Ke70 ground up-every bolt spec. Resto!
    By Teddy in forum KE70 / AE71 Owners Forums
    Last Post: 26th June 2008, 07:20 PM
