Yep, need 4A to T50 RWD
Toyota Genuine part number 11355-15021
Roger!
Paul, I just realized, the 20V rear end plate (2mm sheet metal goes between engine and box) has starter hole on opposite side for FWD.
I was like, aye, all good got a couple of 16V's here, but they both FWD as well?
I take it I need 4AC one or JDM RWD.
Or I butcher 20V one?
I go do a search in tech, got to have been covered.
Think I have one, il have a snoop....
Oh bro....come back to me.
How hot is it today? Its like 41 in the shade.
I know, I'm inside thinking this aircon is shit, then I walked outside and was like yeah, aircon is working just fine...I can't get myself to go out and look for the plate...il do it shortly ,also heading to Darra later so if I find it you can pickup there..
All good, I understand fully.
Shoot me a text if you find it, 0468 371 779 i'll come pick up from where ever.
All good Paul, Just JDM has one, bout to go and pick up now.
Thanks anyway bud!
Bit off a hold up while I source steering parts.
More soon.
Motor and Box in.
Pictures will follow.
I stuffed around with a Howe hydraulic release bearing set up from my 1UZ W57 set up, but I could not get it to work with A-Z customs adapter and T50 Bellhousing.
A-Z adopter is ~10mm thick, and this is why you have to use a pilot bearing spacer with it.
Combined with T50 Bellhousing I had to space the release bearing ~65mm to reach the pressure plate, and it did not leave enough collar for the bearing to sit on safely.
I would have to take ~5mm out of the bellhousing face, and still think it would not work right.
I ended up doing away with it and just used the JDM T50 bell with slightly modified T50 fork to clear the adapter studs.
I believe you could set up the Howe unit with a Nitesparts Bellhousing.
Ed from V-eight.com forums has a nice bolt in bracket that mounts off the input shaft cover for a quarter master unit.
This type of set up has the potential to work with A-Z set up, as it does not rely on the W series collar.
Steering sorted.
Drum brake series 1 T18 Zenki T series acquired.
Hunting for an aftermarket LSD center for right price.
Anyone have experience with the Tomei LSD, price is good, but why $250 cheaper then KAAZ unit?
Can't find anyone praising it on this site.
Are the spare parts easily come by?
Ali
