Results 1 to 5 of 5
Thread: KE70 scrubs after flat front conversion
    Dec 2011
    Eugene
    S.A
    Adelaide Hills
    Default KE70 scrubs after flat front conversion
    Hey guys recently did a flat front conversion with quadlight setup on my ke70. All went pretty well with a few hiccups of stuff not lining up properly but I was expecting that.
    But now however the front tyres grab on the corners of the guards. Has anyone else had this? My car is at the same height with same wheels and it was fine with the slanty guards.
    The wheels are only 14x6.5 and tyres are 185/65/14 so I wouldn't think they would be an issue, maybe my guards are warped? does it both sides.. one worse than the other though.
    I've pulled that corner out as much as I can but it just bends in again when the tyre clips it. I guess only option would be to cut the guards.. just seeing if anyone else had the issue
    Hair model Jacobxxx's Avatar
    Jacob
    Sunshine Coast
    It's just your caster settings making it rub. Smaller tyre would help but most people just cut the bottom of the guard so it clears.
    Veteran drift kid's Avatar
    Glossodia
    Yeah needs a little snip
    Site Supporter Javal's Avatar
    Josho
    Every xE7x that's lowered and runs big castor has this problem. Chop chop.
    Dec 2011
    Eugene
    S.A
    Adelaide Hills
    Yeah I had it aligned so the steering would be a bit lighter. Was fine with the slanty guards but anyway looks like it's getting the chop! Cheers
  1. Ke70 flat front conversion
    By regginblack in forum Car Parts For Sale
    Last Post: 12th April 2013, 06:44 PM
  2. **VIC** KE70 Flat front conversion
    By Shitbox in forum Car Parts For Sale
    Last Post: 7th September 2012, 01:11 AM
  3. [SA] KE70 Flat Front Conversion
    By eS22 in forum Cars or Parts Wanted
    Last Post: 9th January 2012, 07:09 PM
  4. WANTED: ke70 flat front conversion SA
    By KSUP71 in forum Cars or Parts Wanted
    Last Post: 23rd October 2011, 11:11 AM
  5. ke70 flat front conversion
    By stx-16 in forum Technical - Questions
    Last Post: 9th June 2009, 04:17 AM
