Results 1 to 10 of 13
Thread: check out my dizzy and cap. wer can I get one like this?
    Jan 2013
    Gorgi
    Canberra
    gungahlin
    Default check out my dizzy and cap. wer can I get one like this?
    Hey guys here ive got my dizzy thats partially melted from my manifold.
    Id like to know where I can get another with a cap lile this one as I am running aftermarket management.
    Please any help will do. I am using a bigport 4agze but the plug does have 4 bits to it if that helps. U shoupd be able to view the album and have a look. I shall post more pics if needed.
    Muchly appreciated, Gorgi.
    Moderator Sam-Q's Avatar
    Endeavour Hills
    looks like your usual smallport dizzy to me. Just go into an auto store and ask for the ingnition parts to suit an ae93 corolla with a 4age not 4afe.
    Jan 2013
    Gorgi
    Canberra
    gungahlin
    i dont understand how its a smallport dizzy, the head and block look like a big port, i am also getting the head ported and polished atm.. would you like pictures of the head and block??
    ill post them anyway.
    But where can i find a cover like that one, asi dont want coil ends everywhere
    Jan 2013
    Gorgi
    Canberra
    gungahlin
    Here you go
    Its a bigport right?
    Jan 2013
    Gorgi
    Canberra
    gungahlin
    Im a little confused here I thought that the bigport head mist use a bigport dizzy. Or can I interchamge the dizzys for my management needs??
    So I think I have a bigport head but the dizzy looks like a small port. Is this correct??
    So to replace the dizzy I coukd always use the same part number but I am not sure if that cap on the dizzy which eliminates the need for coils is aftermarket or not.
    Endeavour Hills
    yes bigport, might you be able to take the cap and rotor button right off and take a picture from the side view? That way I can give you a better answer.
    You can ignore the cap and use the base of the distributor for it's crank angle sensor and convert to coil packs. Unfortunately I no longer sell blanking covers for the 16V model. I do however have a coil pack conversion plate available still.
    Jan 2013
    Gorgi
    Canberra
    gungahlin
    i am using an Microtech LT10s, with an X4 ingtion System. so i dont think i need to convert to coil packs.
    Could you please show me a picture of the coil pack conversion plate please, as i might grab it if its what i need.
    When i get a spare moment i shall send through a picture. the dizzy still works tho, i just wanted to cover the melted bits, and your conversion pack might just do that for me.
    Thanks Champ
    Jan 2013
    Gorgi
    Canberra
    gungahlin
    OOh and an other question for you sam, Looking at the cylinder heads, can you tell if the whole motor is a bigport?? or just the head?
    Jan 2013
    Gorgi
    Canberra
    gungahlin
    never mind seen the coil pack conversion plates, Looks nice but atm im just looking to get a cover for my dizzy atm
    Veteran slide86's Avatar
    Huw
    Hills
    id say whole motor is bigport. One indication is there is no oil drain in the block. Is it a bigport GZE block? Looks like there is a knock sensor there, 3 rib bigports (AE86) didnt have knock sensors.
  1. Silvertop Dizzy Cap wanted please
    By silvertop in forum Cars or Parts Wanted
    Last Post: 16th April 2011, 06:50 PM
  2. 4age dizzy cap
    By Alexii in forum Cars or Parts Wanted
    Last Post: 19th October 2010, 03:17 PM
  3. 20v Dizzy Cap
    By wideslider in forum Cars or Parts Wanted
    Last Post: 3rd January 2009, 01:06 PM
  4. need a 4age dizzy cap
    By AGENT86 in forum Cars or Parts Wanted
    Last Post: 10th March 2008, 02:13 PM
  5. Dizzy cap experments
    By mikes86 in forum Technical - Questions
    Last Post: 4th June 2007, 09:52 PM
