Results 1 to 9 of 9
Thread: Superpro AE86 Rear Sway Bar Bushes
    Member timmynz83's Avatar
    May 2010
    Ryan
    Surfers Paradise
    Default Superpro AE86 Rear Sway Bar Bushes
    Hey,
    Ive just recently installed my jdm t-series disc brake rear end into my ke70, added all my AJPS gear, really happy, but im having trouble finding the correct superpro D bush for the rear sway bar, the sway bar is a 16mm item from AJPS/signature swaybars but can use a 17mm ID bush and trim it down to suit the sway bar, the bush i originally brought was a SPF0873-17K but its too large to fit into the sway bar D bracket that attaches to the diff.
    Ive done some research on here and google but cant find anyone who's found the correct superpro bush.
    Obviously theres different sized sway bar D brackets.
    My question is, does anyone know the smaller superpro D bush part number to suit this diff?
    My ke70 borgy that i removed has larger D brackets that will take the larger SPF0873-17K bush but the D bracket attaches onto the diff differently than my t-series. Dont really want to unpick the sway bar diff mounts and attach to my new t-series.
    Any help is much appreciated.
    Aug 2013
    Ray
    Vic
    East
    Measure the bracket LxWxH and i'll look it up at work for you.
    May 2010
    Ryan
    Surfers Paradise
    Yea no worries will do that when i return from work in two weeks. Thanks.
    Can also take these measurements and enter them into the superpro website.
    Which i didnt get around to doing before returning to work.
    In the mean time i wondered if anyone else had ordered the correct bush for the smaller D bracket.
    And had a part number.
    AJPS can do super pro bushes too...
    May 2010
    Ryan
    Surfers Paradise
    Yea i brought all my parts including superpro bush kit through David at AJPS but after talking with him we couldnt determine the correct bush.
    I think easiest way is going to be to measure the bracket and enter that into superpro website and then order that bush and give it a go.
    Just thought maybe someone here had had the similar issue with there jdm t-series.
    May 2010
    Ryan
    Surfers Paradise
    So ended up using SPF1690 which comes in 17mm, 18mm, 20mm sway bar sizes. I had a 16mm AJPS/signature rear sway bar so used 17mm SPF1690-17K, and trimmed it down to suit 16mm sway bar.
    Had to trim the edges on the base of the bush to sit flat on sway bar D bracket mount on diff. Pictures supplied below.
    The bush does have 1mm either side of D bracket when mounted on the diff. But clamps up tight when torqued down. And hasn't moved yet.
    Current Cars:
    1974 Mazda 808/RX3 Sedan (In Storage)
    1983 Toyota Trueno AE85, 20V B/T (In Storage)
    1983 Toyota Starlet KP61 Wagon (In Storage)
    1982 Toyota Corolla KE70, Quad Lights, T18 Chrome Bumpers, JDM T-Series, Factory 4K (Daily In GC)
    1983 Toyota Starlet KP61 'Lisse' (Soon To Be Daily)
    Veteran AJPS's Avatar
    Lonsdale
    glad you got it sorted, will change that number over to the ke70 bars
    cheers ryan
    how did you go with the kp?
    May 2010
    Ryan
    Surfers Paradise
    Thanks David.
    Shhhhhhh that's a secret
    Current Cars:
    Veteran anastasios's Avatar
    Taz
    Earlwood
    I also had to grind my bushes down to suit stock jdm ae86 rear swaybar. Only usa stock the correct size.
  1. ae86 rear sway bar
    By _wanna-be_ in forum Technical - Questions
    Last Post: 3rd May 2012, 08:12 AM
  2. ae86 rear sway bar mounts
    By jezza11 in forum Cars or Parts Wanted
    Last Post: 27th March 2010, 12:46 PM
  3. rear trailing arm bushes, superpro, adelaide
    By NathanKe70 in forum Car Parts For Sale
    Last Post: 14th August 2009, 05:07 PM
  4. WTB-AE86 rear sway bar bracket & JDM rear seat.
    By drift kid in forum Cars or Parts Wanted
    Last Post: 15th April 2009, 08:51 AM
  5. Sway bar bushes
    By Moebius in forum Technical - Questions
    Last Post: 16th September 2008, 01:40 AM
