Results 1 to 8 of 8
Thread: Alternator lamp wire not working, can anyone help!
    Member tristybomb's Avatar
    Tristan
    Default Alternator lamp wire not working, can anyone help!
    Hi, I'm having trouble with the lamp wire to work in my ae86. Im wiring a 4age in, I've had the engine running but the alternator isn't charging the battery. I've doubled check the wiring to the alternator and I'm shore I've got it right. I used the [how to wire 4age thread] on here to work it out.
    This is wants going on; when I connect the lamp wire from the fuse box to negative terminal, ignition on, not running, the charge light from the dash comes on. Indicating that it does work. When I plug it into the alternator. The charge light doesn't come on.
    So maybe it's an earth from the alternator? I then checked the earth with a volt meter by using the positive wire to positive battery terminal to anywhere on the alternator and it reads +12v. So the earth is all good. I then check the lamp wire from the alternator and it reads +11v, by then putting the positive volt meter wire onto negative battery terminal it reads -1.85v, so that means there's power coming back through the lamp wire, is this normal?
    So yeah I don't know if its the alternator is stuffed or its an earth issue. Or maybe something else. Can anyone help me out!!
    The alternator earths out thru the casing / mounting bracket.
    do you have the ign pin connected? 12v accessories plus 12v constant power for the sense wire
    Tristan
    Yeah I've got the sense wire and the IGN wire hooked up. Just when I hook the lamp up it doesn't work.
    Seams weird, it should just work. Especially if the light wire is providing an earth when the ignition is on.
    That's how you checked it right? Red wire from multimeter to positive terminal and black to the light wire
    Did you remove the regulator from the 4ac?
    Tristan
    Yeah that's how I checked it. It only reads 11v though. Shouldn't it be 12v? All the 4ac reg is removed
    Senior Member pt_y2k's Avatar
    Paul
    Pop off the alternator, pull off the 3 8mm nuts that hold on the back cover. Loosen the 10mm nut on the positive connection stud. Slide off the cover and take out the 2 Philips screws that hold in the brush box, use a good p3 Philips and catch it right once,they have a habit of slipping...out your meter across the 2 slip rings contacts and check for continuity, I bet there will be none there. Common prob on this end units is the rotor going open circuit thus no charge light.
    Or u could send it off to golberg to be recod
  1. WTB: Working FWD 16v water setup and alternator
    By willa in forum Cars or Parts Wanted
    Last Post: 7th September 2011, 06:02 PM
  2. Replies: 6
    Last Post: 5th September 2010, 09:38 AM
  3. Wire up my Alternator, Starter motor and Fuel pump relay!
    By DRFTAE86 in forum Melbourne & Vic Events and Discussion
    Last Post: 15th March 2010, 12:19 PM
  4. 1 wire or 2 wire o2 sensor?
    Last Post: 20th November 2009, 08:27 PM
  5. shift lamp
    By jono86 in forum Technical - Questions
    Last Post: 23rd August 2006, 08:34 PM
