Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 30
Thread: Fuel - Do l use JDM tank, Mod ADM one or Fuel Cell to handle 4AGTE now
    Senior Member Mirko's Avatar
    Mar 2013
    Mirko
    Default Fuel - Do l use JDM tank, Mod ADM one or Fuel Cell to handle 4AGTE now
    Have a 1985 ae86 which previous owner started doing conversion to 4AGZE. Dropping the super charger and using car for track so was wondering if l should waste my time moding the existing tank to handle EFI or get a jap one or just go straight to fuel Cell. Will be driving on street a little as well so keen to find options that reduce smell like tanks built under the car etc
    Was wanting advice and suggestions and if anyone has done the fuel cell option who did it for them am based in syd
    Easiest solution is to buy a jap tank and use that.. works a treat.
    Otherwise under car surge tank ajps sells works good too with a lift pump in the tank.
    Or mod the ADM tank.
    They all work, unless u are putting out crazy hp you won't need to do too much to the fuel setup.
    Mar 2013
    Mirko
    Have a surge tank from az customs was thinking that with a lift pump and thats done then. Like the idea of the fuel cell as seems cleaner solution for track and later a targa. Not chasing huge around 200kw for now
    Member z_brutalis's Avatar
    Jun 2009
    Robert
    Kealba
    have a look at my technical article on this might suit your needs and found it to be really cost effective
    Mar 2013
    Mirko
    Saw that dude great write up. Question was more around the sense of it. As since its a track focus l dont mind spending the little extra if need be for a fuel cell and running e85
    Veteran johl's Avatar
    Johl
    fuel cell will probably affect resale value if you ever go down that route. unless the car is track only due to defects. simplest solution would be to use a jap tank and that will eliminate the need for a surge tank and lift pump. but it not too hard to throw a lift pump on the adm tank and feed a surge tank to bosch 040 pump.
    Alex
    Wagga Wagga
    For what it's worth, I used to run factory fuel lines and just a VL Turbo fuel pump mounted under the fuel tank for my old 4AGTE. Didn't have any surging issues at all, so long as the tank was above 1/4 full.
    Sure it isn't the 'best' option, but it certainly served it's purpose.
    Alex's 4AGTE KE70
    Or so was thought...
    Mar 2013
    Mirko
    No car can be rego'd no problems. Needs to have surge for track. Might just use adm one and lift pump as well and if need be can always go all out after thanks for thoughts guys
    Mar 2013
    Mirko
ID:	29722 on a side note panel guy is making progress. Guard pumped and now under prep
    Might pay to do the "final" solution now that will exceed your future needs. Fuel cells imo aren't that expensive
  1. JDM or Modified ADM Fuel Tank for Internal Pump
    By gazae86 in forum Cars or Parts Wanted
    Last Post: 15th November 2012, 08:39 AM
  2. Replies: 3
    Last Post: 13th April 2012, 03:11 PM
  3. WTB: ADM or JDM ae86 fuel tank
    By stylz in forum Cars or Parts Wanted
    Last Post: 1st January 2009, 05:08 PM
  4. ADM & JDM AE86 fuel tank
    By AE86.cn in forum General Topics (No Technical Questions)
    Last Post: 29th January 2008, 10:22 PM
  5. JDM Fuel tank, fuel pump and sender wanted
    By Toyo86 in forum Cars or Parts Wanted
    Last Post: 9th August 2007, 10:10 AM
