Results 1 to 3 of 3
Thread: QLD FS ke70 part out got the goods
    Member jackthecat's Avatar
    Jul 2010
    Jack
    Ferny Hills
    Default QLD FS ke70 part out got the goods
    QLD can post can text photos 0468 940 942 all prices are ono but dont be stupid low balls can make package prices
    will post photos up later when i can be bothered
    engine - JDM small port full RWD set up w/toda 288/272,silver top ITB on T3 manifold with custom 130mm trumpets and eagle vaccum block , Coil on plug, old school hks cam gears metal head gasket, maybe some other mystery internal mods. ports look stock. billet flywheel with mocal oil thermostat sandwich plate with earls -10 fittings and lines to cooler and has a -3 earls to tee so u can run oil temp/pressure ECU Haltech E8 with very tucked loom
    comes with striped down 7a block also
    $3500
    ae71 pedal box $200
    ae71 crossmember $150
    xt130 Lca $100
    Alloy radiator ae86 with davies craig 12" and rwd red silicone pipes $200
    3 puck built by NPC for W58 gearbox with metal plate w58 on a 4a bell housing with a AZ custom adaptor with front part of tail shaft $2000
    exhaust - full bolt on RSR with test pipe , single rear muffler with silencer installed (60mm) 4-1 mild steel jap header $500
    cusco tower brace $120
    40mm shortend struts with otomoto kit with 8k springs and kyb agx mr2 dampener. PS knuckles, AJPS 40mm rca, AJPS extra lock rack ends, what i suspect is tein camber tops,. JDM rda vented slotted dimpled discs with ADM calipers using QFM A1RM pads with -3 earls brake lines $1500
    mcnsport avo rear coilovers 5kg $600
    ajps traction brackets $120
    whiteline pan hard rod $100
    t18 s1 with swaybar mounts welded on with TRD 2 way with 4.3 c/p with only 4000km on it from rebuild by top cog with rear part of tail shaft 1300
    velo seats with side mounts and ae86/ke70 bases $1300
    fake defi gauges, water temp, oil temp, oil pressure, volts $100
    most stuff is new less the 10km on it other then motor and gearbox
    Jan 2013
    Gorgi
    Canberra
    gungahlin
    Can we see pics of the seats please.
    Jake
    Northgate
    Sell anything cheaper for multiple items?
  1. (QLD) Daily Ke70 with all the goods. Except a 4age......
    By wagonlife in forum Cars for Sale (Toyota Only)
    Last Post: 18th August 2013, 09:25 AM
  2. FS: KE70 XX Sedan QLD
    By Ellimist in forum Cars for Sale (Toyota Only)
    Last Post: 13th December 2007, 09:08 PM
