Results 1 to 10 of 12
Thread: Running a thermo fan from stock BT 20v ecu
    Member _sawyer_'s Avatar
    Feb 2010
    Paul
    West melbourne
    Default Running a thermo fan from stock BT 20v ecu
    Hey everyone,
    I'm S T RUGGLING with this one, Im so close to the end of my Ae86 build and I'm finalising some loose ends here and there which I've been putting off.
    Im having trouble with my thermo fan. Im running the stock bt ecu and I have isolated the output from it to trigger a thermo fan relay but there dosent seem to be enough current to operate a standard relay.
    Has anyone come across this?
    Ive been told to run a micro relay (or something like that) to run another relay to the fan but im not having any luck finding it.
    Cheers ae86 guru's
    Moderator
    Jay
    mine just runs all the time
    this probably doesn't help
    Feb 2010
    Paul
    West melbourne
    lol.... not realy
    The thermo fan input on a blacktop ecu is purely for the ecu idle controls. It's an input not output.
    Get a thermofan relay from any fwd rolla and wire that in. The relay is reversed, when u earth it out there is no power.
    Off the the thermostat housing is the single green plug, run that to the earth of the relay and when it's cold the housing provides an earth.
    once it gets hot then it will stop and the fan turns on. I'll try and get some pics for u over the weekend
    Feb 2010
    Paul
    West melbourne
    Thanks for the reply matt,
    Do you have the ecu pinout handy?
    The signal I get from the ecu is from ELS1
    And yes like you said, theres no power on this wire when earthed, There for when heat increases, resistance increases, its then no longer in a earthed state and fires up the fan
    Or am I just confused?
    Senior Member Dylan's Avatar
    Dylan
    Electrical load sense 1 - def an input for the ecu. The ecu is expecting a 12v input when the thermo fan is running
    That wire run directly to the earth on the thermo relay.
    It comes out in this plug on the loom
    For the power to the relay I'd just run a wire direct to the battery via a 30amp fuse and join the 2 power pins together.
    I'll grab a relay in a min and show u
    Feb 2010
    Paul
    West melbourne
    Thanks for the detailed reply, on second thought I think im getting a trigger from the ecu from the "cf" pin, is that the correct one?
    If you are in the ae111 from factory they don't use it.
    Feb 2010
    Paul
    West melbourne
    Thanks for the advice and photos mate, got the fan running properly and keeping the donk as cool as a cucumber!
  1. 20v bt loom and ecu
    By dehney in forum Cars or Parts Wanted
    Last Post: 28th October 2012, 05:56 PM
  2. wtb stock 20v bt ecu
    By MattybT184age in forum Cars or Parts Wanted
    Last Post: 4th September 2012, 12:13 AM
  3. stock 4agze ecu, was running in my car.
    By danny_ke70 in forum Car Parts For Sale
    Last Post: 2nd February 2011, 08:18 PM
  4. 20v RWD water kit, exp & thermo fan
    By Gunner in forum Car Parts For Sale
    Last Post: 4th January 2010, 12:34 PM
