Results 1 to 6 of 6
Thread: 1jzgte vvti Corona Wagon
    Senior Member dangdang's Avatar
    Aug 2010
    Danga
    Tas
    Aus
    Default 1jzgte vvti Corona Wagon
    FOR SALE:
    st141 Corona Wagon, registered.
    jzx100 1jzgte vvti
    High flow Kando ct15b turbo cartridge with garret 60-1 comp housing and steel exhaust wheel
    Jzx100 PowerFc with EL model hand controller
    Weld Logic intercooler piping, front mount and alloy radiator with thermo fan.
    Factory 'J' pipe inlet removed and custom turbo intake pipe fitted
    3" exhaust
    Dyno tuned by Andrew at Pro Automotive, 220rwkw on 15psi
    jza80 w58 gearbox
    Custom NPC clutch based on a 7mgte pressure plate with a sprung six button centre
    Floor mounted Jazz foam filled fuel cell with dash fittings and gravity fed bosch 044 pump
    7.5" F series Tarago diff with brackets fabricated to suit,
    Welded 4.3 centre, freshly setup with new pinion bearing, crush spacer and side bearings
    Custom tig welded 3/4 unc turnbuckled upper rear control arms for pinion angle adjustment
    AJPS rear adjustable spring seats
    AJPS 6kg rear springs
    8 way adjustable TRD blue rear shocks
    Adjustable panhard bar
    ma61 supra front struts with king springs and KYB inserts
    ma61 supra front calipers and discs
    Lengthened LCA's
    ra60 Celica power steering knuckles
    AJPS rack spacer
    All new balljoints, tierod and rack ends
    All urethane bushings throughout car
    ma61 supra seats
    Speco boost gauge
    TRD gear knob
    Kenwood CD player
    Roof racks
    Comes with 15x8 challengers and near new Kumho ku31 195/50r15's
    Quick street sleeper, bash 12 rims and tyres in the back and drive to the track.
    $7000
    TAS Rego
    Link below for more info
    Senior Member briigo82's Avatar
    Dec 2010
    Josh
    qld
    Strathpine
    Nooooooo! Don't sell
    Aug 2010
    Danga
    Tas
    Aus
    Yeeeees please buy!!!
    Common seriously somebody must want?
    The things fair well sorted and goes like stink.
    Aug 2010
    Danga
    Tas
    Aus
    SOLD
    Aug 2010
    Geoff
    mt dandenong
    Cool. Sounded like a good ride
    Whoever bought it is a lucky 1jz driver.
  1. TRD inlet suit vvti or no vvti BEAMS
    By Celica RA45 in forum Car Parts For Sale
    Last Post: 29th May 2011, 04:33 PM
  2. Replies: 1
    Last Post: 22nd June 2010, 04:32 PM
  3. wtb td06 turbo kit for vvti 1jzgte :)
    By pig_086 in forum Cars or Parts Wanted
    Last Post: 3rd May 2010, 11:23 PM
  4. GX70G Mark II Wagon - vvti 1JZGTE, Brisbane.
    By cha54 in forum Cars for Sale (Toyota Only)
    Last Post: 7th September 2009, 06:49 PM
  5. Corona wagon - I want one
    By Konakid in forum Offtopic Discussions
    Last Post: 27th February 2009, 04:49 PM
