fuuckk, tuff as. Loving the double handy brake.
What rear brakes are you running with that hydro?
ANY UPDATE ON THIS MIKE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
ya slack fk!
running standard T series drums for the moment. I will be upgrading to a r31 disk rear end so it should work quite well just hooked up to the r31 callipers.
I wanna test it and see how the hand brake goes before investing on a second caliper arrangement due to the cost involved, and seriously the costs just keep mounting with this build!!!
Hey Guys, Mini update.
I have finally pulled my finger out (well since my mate said it could no longer stay at his house unless it is finished by the end of june!!!) so I have bitten the bullet and getting the guys at WTF auto here in Perth to wire-up a Haltech Platinum Sport to get the beast running, as well as a few odds and ends that would be time and cost effective just to get them to do.
The reason I am goin haltech is because these guys have put them in many cars and should end up being cheaper because there will be less labour than getting another ecu installed...hopefully.
But before that I have a lot to finish:
- cooling system including turbo and header tank fitting
- Dash needs to be redone and gauges fitted properly
- rear brakes need to be hooked up to hydro handbrake
- suspension needs to be raised (to get onto the trailer) and tie rod ends refitted, after the basted that stole them did not refit the new ones before he moved to melbourne.
And amongst all this I need to source an r31 diff before I can get it dyno'd so I dont blow the rare s-series 2way thats on it now. I might have to get the car running on a base map before I get diff and tailshaft fitted. but we shall see.
Anyone know the diff codes and ratios for r31 diffs? I havent come across them yet?
i know that the pintara diffs are 4.1, and its a borgwarner
this might help also
Been so slack lately but going out an staring at has taken its toll and I now have the motorvation to race this thing. I have funds just need some parts!!!
So help me out guys, I need :
- a good w58 preferably ga70 shifter position
- r31 LSD diff from a silhouette / trx pintara sedan
Preferably both in Perth but if postage aint too expensive then shouldn't be a problem
Please help, beers offered in appreciation for anyone that can directly help me secure these items for good price![]()
