Tried sam q ron? Looks like the kind of thing he'd make/stock
Had a look at his site and there isn't anything on there. Will PM him anyway just in case.
how much longer does the bypass tube need to be over a stock one?
Not sure on exact length. I cut mine and joined it with some hose. I will take a measurement today and let you know but it won't be exact. Also without a spacer for the outlet housing, the pipes won't line up. I managed to make a spacer for the outlet by cutting 10mm off the end of an old broken outlet housing I had. Worked out perfect.
cool, was just going to say that a 4ac bypass pipe is identical in design, but around 10mm or so longer
Cheers, It might be a fraction short still but I will check it out. Thanks.
