Hi,
1. I have an F38 wastegate that I don't seem to require any longer. It's technically brand new as I sent it back to TiAl and had them replace the body on it as it was warped. Everything checked out after that. Comes with a 7 psi spring from memory (small green). - 200 bucks OBO
2. Got a RWD sandwich plate from a 4A-C if someone wants it. 50 bucks OBO. I can go and grab a pic if you want but it's black and covered in clutch dust/road grime/oil/grease/whatever. No rust on it.
3. I got this AW11 GZE ECU forever ago knowing that it was broken. If anyone wants it, they can have it. If you want me to de-solder the plug off it to make a plug in patch harness for adaptronic or whatever, I can do that for 20 bucks.
Thanks.
Found a flange for the 38mm with gaskets (2) which will be included with the gate.
