Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
Thread: Need Help With Suspension Setup
    Jordan
    Default Need Help With Suspension Setup
    Hey guys, I'm new to all this so a bit lost with new suspension setup for my AE71.
    Things I need to know:
    -What's the best stuff to get for a suspension setup for an AE71 street car? How much will it cost? I'll be doing a fair bit of driving in the hills if that helps
    -How much will AE86 front struts cost approximately?
    Thanks for the help.
    Veteran slide86's Avatar
    Huw
    Hills
    this is a pretty open question, lots of people have different opinions.
    there are several different threads that you should read up and learn spring rates and the like
    i would suggest getting in contact with ajps, dave will be able to recommend some good spring rates and shocks for you.
    get some ae86 struts, ae86 jdm brakes, T series diff (drum will be fine) selby swaybars and suitable shocks/springs.
    the thing will be sweet, but be prepared to spend a few grand on the sus, its the only way to go to get it right
    Jordan
    Yeah, probably not possible...
    I don't have a whole lot of money and at least a grand of it is going into a 4AGE, a grand on wheels and tyres. I'll have only about a grand for suspension.
    You know how much the struts and brakes will cost?
    This thing will be more of a fun daily, probably won't be drifted
    Jordan
    Anyone?
    Senior Member resol's Avatar
    steve
    vic
    mate get your priorities right first before you begin a project.
    you mentioned hills. well brakes and susp are pretty damned important (for most driving i know but in particular) for hills.
    a well balanced car will perform best, i.e not too stiff front vs. rear like some drift corollas seem to be setup.
    IMO spend your money where it counts. sick wheels look good and can allow for bigger better tyres. but will you be putting good tyres on?
    a 4age is a failry easy engine swap for some increase in power, but unless you have the susp and brakes to utealise it, then whats the point?
    im a big fan of suspension. so i say set that up first then start worrying about engine/power etc. ma61 rims and the like are cheap and let you run bigger tyres without troubles. save some cash in the short term at least...
    -dan
    gunner:
    ALL DRIFT MODIFICATIONS
    Huw
    Hills
    defiently get the sus before the engine.
    there is no point having a car with some power if the chassis cant actually handle or you cant handle it
    Veteran Konakid's Avatar
    Henry
    Eastern
    Basic sus setup
    AE86 struts w brakes - 250
    AE86 P/S arms - 150
    re bushed 10mm longer control arms - 200
    Castor rod bushes - 50
    New tie rod ends, rack ends - 150
    Strut brace - 150
    KYB Excel g short strokes all round- 400
    6 and 4.5 kg springs - 500
    Adjustable Panhard rod - 150
    =$2000
    I wouldnt bother doing any less, as only doing the majority of those mods would highlight the huge downfall in the parts that you missed out.
    Andrew
    Where are you buying your springs? Kings are $120 a pair.
    Try some xt130 struts and even go the ra60 calipers and discs straight off. I paid $130 for complete xt130 struts from the wrecker. May be slightly dearer now.
    Reco'd MX62 calipers $200 (I have these if you are interested) You'll need to slightly grind the strut tabs and fit some spacers/washers. There is a writeup on toymods about this.
    New ra60 discs $150 (can also use wrecker discs and machine them to save a few bucks.
    New rack ends $150
    Caster rod bushes $50?
    LCA bushes $50?
    New tie rod ends $50
    New ball joints $50
    New pads $50 (I have these too)
    Springs front and rear $250
    KYB shocks (take konakids word for it at $400 for front and rear, I've never bought the excel g's)
    Probably need adjustable panhard bar. $150
    Total $1680 and you'll have sweet, sweet brakes and suspension.
    This is just an approximation but i'd say it's within $100
    I wouldn't bother with the power steer arms to start with. If you decide you want faster steering you can easily upgrade to them later or go the whole hog and throw a quaife rack in it.
    Strut brace is nice but can wait.
    Henry
    Eastern
    ...and kings springs are about 25mm lower than stock and only 5% harder.
    Not worth the money.
    The springs im talking about are AJPS ones, decent rate, decent heights, good quality made in adelaide.
    think a full set is about 450 all up, just made it 500 for calculations sake.
    Andrew
    Fair enough. Add $250 to my estimate, brings it up to around $1900.
  1. Your Suspension Setup
    By sonsta in forum Technical - Articles
    Last Post: 30th April 2014, 01:39 PM
  2. (SA) *E7*/86 BC/AJPS Rear Suspension setup/ 2871r turbo setup
    By sleeper_13 in forum Car Parts For Sale
    Last Post: 25th July 2012, 01:06 AM
  3. ke70 suspension setup
    By biggo in forum Car Parts For Sale
    Last Post: 9th January 2008, 12:16 PM
  4. WTB::: suspension setup
    By winslow in forum Cars or Parts Wanted
    Last Post: 16th August 2007, 04:53 PM
  5. suspension setup
    By AE86_4life in forum Technical - Questions
    Last Post: 1st November 2006, 08:43 PM
