Results 1 to 10 of 16
Thread: Power fc + itbs
    Jan 2013
    Daniel
    Qld
    Forest lake
    Default Power fc + itbs
    Hey guys,
    I've recently gotten myself a power fc. Reason I got it was simply due the the plug and play factor, meaning less money spent on trying to wire it all up.
    Now I've had a talk to a tuner, and he said it'll be a bit of a problem trying to get the 4age running properly with itb's. I've always thought being a full stand alone ecu it'll be alright.
    Can someone shed some light ?
    Im sure plenty of people have done this setup, but he makes it sound like it's doable, but rough at idle etc.
    He also mentioned something about Map sensor on the 4age, said that it'll have trouble tuning with just map sensor :/
    Any help would be highly appreciated !
    Jun 2011
    james
    oxford
    general area
    England
    The problem you are likely to encounter is a low and fluctuating Map signal. Do a search for "map + itb"
    If the power F-C can tune alpha-n which uses rpm as the load then you will have no problem.
    Alpha-n essentially uses TPS vs RPM for the fueling and ignores the Map signal
    Jan 2013
    Daniel
    Qld
    Forest lake
    I've looked into that, but I can never get a straight answer. If the tuner isn't confident enough I might just have to sell it and use the emanage blue I have, even though it's just a piggy back.
    If I can find a thread on how to wire tps signal in rather than using map signal, I'll tell mention it to the tuner and see what he can do
    Veteran Skylar's Avatar
    Ken
    I guess you could do a straight TPS tune but it's not the best way of doing things.
    The emanage isn't much better in this application either.
    Just sell both and buy something that does alpha-N, as a tuning mode which you select, or better yet, 4d tuning (tps/map blending<-the proper way). Even janky meggasquirts can do it in what they call "ITB mode". Megasquirts are pretty cheap if you're keen and and willing to learn a bunch of stuff about electronics, and even tuning. Whole set up tuned including wideband and some jaycar amplifier based knock ears is only like 750... but a shitload of your time.
    Aug 2010
    Geoff
    mt dandenong
    Quick question, is the motor stock?
    If it is there isnt really any gains to be had for the hassle of getting it to run well with quads.
    Unless your raising the compression and running cams your otherwise stock bigport will most likely have less bottom end power but better top end, good for track, not so good for daily driving
    Jan 2013
    Daniel
    Qld
    Forest lake
    Yes the car is stock with just bolt ons. However I bought the car like that and I have the computer. I mainly just want to run better and not so rich. When I mean rich, I mean rich rich. I looked into megasquirt, Im in no way able to tune something programable, I suck at that shit. Should've just bought an adaptronic
    Power fc's are so hard to sell since there's competing ecu's for about the same price, newer and allow more tunable applications
    Ken
    PFC's have a use and that's stock setup turbo engines, when you don't mind keeping single coil and distributor. Then again, if you wanna sell it, it's gonna have to be pretty cheap since it can't do much, especially compared to base level vipec/haltech/adaptronic. It's as basic as an MSnSE and makes the MS2 look way superior even though it's a real simple ecu.
    I can tell you how to connect tps wire to map wire but 1. I would rather you didn't do that and 2. your tuner should already know how to do that.
    May 2012
    ACT
    belconnen
    It doesn't look like Powerfc's support alpha-n tuning, or at least it isn't an option that I could find in FC-edit. However, you could probably get it to work if you wired the TPS signal to the load input (MAP or MAF), and get whatever tuner to tune it as if the load axis was TPS.
    Jan 2013
    Daniel
    Qld
    Forest lake
    So right now I'm weighing between a adaptronic or a megasquirt. Obviously pros on megasquirt is I can get it in plug and play form also, meaning less labour for wiring. But tuning is the part that worries me. It's an American ecu, I've no idea who in Brisbane would tune it :/
    Aug 2010
    Geoff
    mt dandenong
    Best thing to do is find a tuner with a good reputation work with 4age's and ask him which ecu to go with.
    Alot of different ecu's require software to accompany them, tuners have to pay for the software and sometimes a licensing fee to use it.
    Best to call around and meet some pros in the area and get some advice
  1. 20v silvertop + itbs power gain?
    By theknickerbocker in forum Technical - Questions
    Last Post: 25th October 2013, 10:54 AM
  2. Apexi Power FC
    By AE86R in forum Technical - Questions
    Last Post: 3rd April 2009, 09:02 AM
  3. who has power fc? or a 7age managment
    By wide s13 in forum General Topics (No Technical Questions)
    Last Post: 2nd January 2009, 03:30 PM
  4. Power FC for 4AGE
    By Mattysshop in forum General Topics (No Technical Questions)
    Last Post: 3rd January 2006, 07:46 AM
