Results 1 to 7 of 7
Thread: 4age water temp senders. which ones which
    Dec 2013
    Trent
    qld
    Jimboomba
    down under
    Default 4age water temp senders. which ones which
    Hi all, i am getting prepared to install a vipec ecu. Is the temp sensor on the water outlet pipe where the top radiator hose joins on for the gauge and the one at the back of the engine for the ecu. Does it make a difference. Also there are two sensors at the back of the engine, why? Cheers, Trent
    Dec 2013
    Trent
    qld
    Jimboomba
    down under
ID:	30636Pictured is the back of the motor 2 wire sensors while the one at the front only has 1 wire
    Senior Member Dylan's Avatar
    Dylan
    The one on the front of the engine is only for the dash gauge, the two sensors on the back are for coolant temperature for the ecu(green) and operation of the cold start injector(brown)
    Use the green one for the ECU coolant signal
    Dec 2013
    Trent
    qld
    Jimboomba
    down under
    Thanks heaps! I appreciate it. Trent
    Dec 2013
    Trent
    qld
    Jimboomba
    down under
    Another quick question. Would i get the same temp reading at the front of the engine as the back. My ecu came with a new water temp sensor but its 1/8 npt and the rear temp sensor port looks like m12x1.5 or something and i have an adapter 1/8npt to 3/8npt so i could use it on the radiator outlet pipe but not at the back of the engine. Would this be a problem? Cheers
    Dec 2013
    Trent
    qld
    Jimboomba
    down under
    Well my water outlet pipe isnt even 3/8 npt. M14x1.5? Found what i need anyway autometer 2277 for rear temp sensor.
    Dylan
    The front should be m16x1.5 rear is m12x1.5, if you replace the rear sensor with the adapter and your new sensor that will be fine.
  1. water temp sensor same between 4age and 4k.
    Last Post: 17th July 2012, 11:32 AM
  2. 4AGE 20v Water Temp Sensor 89428-12160
    By Stain in forum Cars or Parts Wanted
    Last Post: 6th April 2011, 07:43 PM
  3. WTB: Gauges, Oil Temp, Water Temp, Oil Press.
    By Robo86 in forum Cars or Parts Wanted
    Last Post: 30th July 2009, 09:16 PM
  4. Gauges - oil temp & press & water Temp
    By NIZLAH in forum Car Parts For Sale
    Last Post: 26th February 2009, 11:12 PM
  5. FS - Water Temp Guage
    By aeke7086 in forum Car Parts For Sale
    Last Post: 25th February 2007, 11:04 PM
