a is around 930 center to center
b is 880
Hello guys,
I am doing a diy rust repair job on my AE70. i was overwhelmed by the amount of rust and i had to cut out the rear wheel wells. however, i forgot to take some measurements, and now it's time to weld new sheet metal into place, but i don't remember how wide the shocks are apart or the angle. i don't know how i 4got to measure b4 cutting.
Please someone help me and measure distance A and B in the sketch i have drawn below. it will help alot.
Thanks.
Max
b is 880
You could always widen the inner archers and move the shockies in so you can use wider rims without having them stick out. Since its apart anyhow.
yeah, because the shocks lean inwards i measured low inline with the rubber bush. it would be with in a mm or so i think.
