Results 1 to 10 of 10
Thread: Help identifying this gearbox - t50 TRD?
    Aug 2012
    Jarrad
    east
    Default Help identifying this gearbox - t50 TRD?
    Hello wonderful mechanical experts, of which I am not!
    I purchased this box a while back, and never took any notice until moving it today.
    Now it's apparently a T50 -> 4age box - and it appears to have an ADM 4AGE bellhousing.
    I noticed it has "TRD" stamped on it, as well as the TEQ on the same part of the gearbox.
    Is anyone able to shed some light on this, what it may possibly be, what it may mean etc.?
    I know TRD developed a close ratio box, but would they stamp it as well?
    Thanks for any help in advance!
ID:	30689Click image for larger version.
ID:	30690Click image for larger version.
ID:	30691Click image for larger version.
    Senior Member KE70GT's Avatar
    Gavin
    kilmore
    I don't know what's in the gearbox but I don't think that casing is TRD they wouldn't take two attempts to press the D in trd so that's been done by someone else but it could still have trd bits in it
    Veteran AJPS's Avatar
    Lonsdale
    its definitely been opened at some stage
    Aug 2012
    Jarrad
    east
    It's 100% been opened, I know that for fact, haha.
    And yes, KE70GT, I thought exactly the same thing in regards to the D. But then thought "Why would anyone go to that effort?"
    It wasn't advertised as TRD when I bought it, just as a regular T50 box.
    So if it wasn't for advertising purposes to try and drive the price up, what purpose would that serve?
    But, still, does anyone know of Toyota stamping boxes/and what it may mean, regardless of this box in particular?
    Gavin
    kilmore
    if you have enough money to be buying trd gearbox parts you would probably have 5 or 6 t50's lying around the place some broken some good and some with trd parts in them id be stamping the trd one with trd not to be confused I know I have 6 t50's in my garage and I know atleast three of them arn't any good but i've forgot which ones gotta pull them apart and find out some time lol
    Aug 2012
    Jarrad
    east
    Hmm, a convincing explanation indeed.
    A stamp doesn't come off like a piece of tape might haha.
    Well, no idea what the box drives like. Guess I'll find out once it's in the car. Not expecting anything more than a regular t50, but would be a nice surprise for something extra, haha.
    Bryan
    Waterford
    Tramore
    Ireland
    Open the box and check if the main section of lay shaft is 1 piece or separate gears splined onto the shaft.
    Senior Member Willofan's Avatar
    Jan 2011
    Caringbah
    I have stamped each of my boxes with the 1st gear ratio with Q for Quaife, TRD and Std so I know which one to use at each circuit.
    Suggest opening it up and checking before you put it in, for the cost of a few gaskets and front & rear seal it is easy to do. Then you know what you have.
    My concern would be if 1st gear is a 2.34:1, it would be hard on your clutch if you are using it as your daily.
    West
    Cant you just approximate the ratios from comparing in and out rotation, that will tell you, the ratios are wildly different on the trd gear sets, especially first.
    Veteran timbo's Avatar
    Tim?
    Wild West
    Gear sets are TRD, not cases. Do as LittleRedSpirit said, easiest way to check. I'd take a punt on extra $$$ by means of letter punches. Could also be a great find.
  1. TRD close range gear set T50 Gearbox and TRD 4.8 two way
    By RolandGTV85 in forum Technical - Questions
    Last Post: 1st November 2013, 08:00 PM
  2. JDM T50 22 spline gearbox and K50 Gearbox
    By wrathchild in forum Car Parts For Sale
    Last Post: 19th September 2013, 08:03 PM
  3. CA Gearbox, T50 Gearbox, Ecu's,Exhaust QLD
    By damien454 in forum Car Parts For Sale
    Last Post: 23rd July 2012, 01:02 AM
  4. identifying gearbox t50 or k50 piks inside
    Last Post: 17th July 2011, 11:21 PM
  5. JDM T50 Gearbox, TRD Blue Rear Short Strokes (ADL)
    By federal in forum Car Parts For Sale
    Last Post: 9th May 2008, 12:41 PM
