Results 1 to 10 of 16
Thread: [TAS] ULTRA DIRECT IGNITION SYSTEM (UDI for CDI) jap
    Dec 2012
    Avi
    East
    Default [TAS] ULTRA DIRECT IGNITION SYSTEM (CDI for UDI)
    NOW LOCATED IN MELBOURNE EASTERN SUBURBS
    Bought this and never got to try it, went straight to aftermarket
    The CDI unit looks a bit rough, but was pulled as a working ignition from a ae86 jap import car with a Blacktop 20v before i got it.
    It is a batchfiring/waste-spark setup, firing in cylinder pairs. its got:
    Ultra CDI Ignition section loom and plugs, one plug to main engine harness, 4 wires, igt,igf,+12,- (im pretty sure, there's definitely only 4 wires to the plug so I assume these are something like that)
    FSD unit (fire sequence determination..)
    ULTRA CDi unit - looks like CRAP, main reason i went straight to aftermarket. will probably need to be tested before installing, someone opened it before i did and cut away insulating silicone, case is cracked but the card is intact and all fine, no black burnt bits, its definitely been tested in some way previously, so its either busted or working. I have no idea never tried it, can't test it.
    Individual ULTRA coils and great leads
    20v Blacktop 4age stock ECU M/T
    Hall effect sensor and bracket attaching to exhaust cam pulley.. theres some info here: 3rd photo down is the same looking setup as this one.
    Good cheap solution for dizzy-less ignition DLi for rwd ae101, ae111 etc or even for 16v for crazy spark
    $250
    - you can buy yourself another new aftermarket cdi (MSD?) for 200 bucks
    if worried about the Ultra's condition. Sorry guys I have no idea if the cdi works or not I don't know how to test it cause its 450volts apparently, don't want to play around in there.
    Its been priced accordingly, still a cheap legal alternative to aftermarket.
ID:	30777Click image for larger version.
ID:	30778Click image for larger version.
ID:	30779Click image for larger version.
ID:	30780Click image for larger version.
ID:	30781Click image for larger version.
ID:	30782Click image for larger version.
ID:	30783Click image for larger version.
ID:	30784Click image for larger version.
ID:	30785Click image for larger version.
ID:	30786Click image for larger version.
ID:	30787Click image for larger version.
ID:	30788Click image for larger version.
ID:	30789Click image for larger version.
ID:	30790Click image for larger version.
ID:	30791Click image for larger version.
ID:	30792Click image for larger version.
ID:	30793Click image for larger version.
ID:	30794Click image for larger version.
ID:	30706   Click image for larger version.
    Dec 2012
    Avi
    East
    Pics up, bumps
    Loom pictured hanging outta car will be included in sale, brand new wiring, don't need it
    Dec 2012
    Avi
    East
    bumpa..
    Jun 2013
    Jory
    Surfers Paradise
    Alrite, Did this come off a 4AGE 20V Blacktop AE86 Conversion? becuase this is what mine looks like right now As of todayClick image for larger version.
    Will this work with my AE111 Blacktop Setup. Becuase looks allot cheaper then going down the Aftermarket ECU + the cost of Dyno tune and Getting it all wired up.
    Only asking becuase you said it came out of a Jap AE86. If it wasnt a Blacktop Motor then i dont think it will work.
    Dec 2012
    Avi
    East
    Hi, yes from a Blacktop 4ager. Comes with 4age Blacktop ECU and a ecu long loom to get you going, will need a 20v engine loom for the sensors unless already on your engine.
    Much cheaper than aftermarket, and has a really high intensity spark, apparently can fire even the most fouled up plugs its spark is really hot, good burn etc etc
    waste spark, so spark on exhaust stroke too
    check out link, mostly all there
    Hall sensor mounts to the exhaust cam,
    plug in all the plugs into the varies devices from the ignition section of the loom
    plug in spark leads
    wire in igf, igt, 12+ and ground into main ignition plug
    and complete wiring of the ecu pins ie sensors, cas, injectors etc
    I am definitely no expert, I have just read this on varies forums, seems like its more popular o.s. than here
    hope this helps
    Dec 2012
    Avi
    East
    Bump, $250
    Dec 2012
    Avi
    East
    Bump
    Dec 2012
    Avi
    East
    bump,
    guess everyone here is well loaded and doesn't need sweet-cheap-stock-shit!?
    its been in my boot since November in tas, I'm moving to melb soon and if this doesnt go and is still in my boot, then i may as well run it on the 16v over there, I'll get to see if it makes any difference after-all.
    That means the Blacktop ECU will go separately if anyone needs one
    Jun 2013
    Jory
    Surfers Paradise
    I dont think its that man, Its just it seems untested, When you rebuild a Engine you buy you dont really want to cut corners you know. After you test it in a 16v and Get it working you should be able to sell that for $700
    Dec 2012
    Avi
    East
    if you don't care about the nostalgic Ultra jap brand you could just buy a MSD of ebay for another 200 bucks. Guaranteed to work then? a complete ignition for any 4age donk? (16v needs a ecu +50$) pretty good for 450.
    anyways, yeah like you say I may just fit it over in melb and see how it goes.
    I bought it just to test my blacktop, but I never got to that stage, having to move soon I just needed the car to drive, so i forked out for a haltech. cost of another Bt.
    Bought it from Anthony Kellam (Kaizen garage) on this site for like 320 i cant remember, he sold it to me as a working stock ignition system for my BT he had just pulled from an import with bt20v.
    His customer was upgrading from that to aftermarket.
  1. freedom ecu, ae86 clutch fan and M.D.I direct ignition system
    By royal flush in forum Car Parts For Sale
    Last Post: 4th October 2012, 05:51 PM
  2. 4a 16v multi coil direct ignition
    By sundee in forum Technical - Questions
    Last Post: 27th April 2009, 12:12 AM
  3. dli ignition system
    By darkness86 in forum Technical - Questions
    Last Post: 14th May 2007, 05:30 PM
  4. direct ignition for 4age
    By mtgg85 in forum Technical - Questions
    Last Post: 14th August 2006, 07:30 PM
  5. Ignition system problems
    By johnO2 in forum Technical - Questions
    Last Post: 9th April 2006, 12:15 PM
