Results 1 to 3 of 3
Thread: VIC WTB 42mm Crank or Bottom End
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    Default VIC WTB 42mm Crank or Bottom End
    Hey guys, I need a crank to suit 42mm big end journals. Will also take a complete bottom end if necessary. If it's black from burnt oil or has damaged a bearing I'm not interested as I already have several cranks like them and they all have heat cracks.
    Call me on 0448 076 716, or PM on here.
    Veteran willa's Avatar
    Will
    Northern 'burbs
    Hey mate, I've got a complete gze small port bottom end with head still attached. I bought it as a running front cut from an ae92 or similar but the block has a crack at the front engine mount. Would that crank be the right size?
    Cheers, Will.
    SuperFunHappySliders
    SR's are ghey.
    Mar 2011
    Mt Dandenong
    It would be the right journal size, only bluetop 4A's are the smaller journal. I only really need the crank/bottom end, would you separate them?
  1. WTB: 42mm crank. (PLEASE)
    By Deeken in forum Cars or Parts Wanted
    Last Post: 14th August 2011, 03:17 PM
  2. WTB: Complete 7A bottom end - VIC
    By boh086 in forum Cars or Parts Wanted
    Last Post: 14th June 2010, 01:52 PM
  3. wtb 42mm crank
    By hinricp in forum Cars or Parts Wanted
    Last Post: 11th May 2009, 08:29 PM
  4. WTB: Crank 42mm - GZE or 20v
    By v-tec in forum Cars or Parts Wanted
    Last Post: 16th April 2009, 01:23 PM
  5. 7a bottom end and crank
    By grantobius in forum Cars or Parts Wanted
    Last Post: 7th April 2009, 06:39 PM
