does anyone have the little inspection plate that sits at the bottom of the bell housing and block??
In a RWD setup its one large sandwich plate that bolts to the block behind the flywheel.
If you can see your flywheel with the gearbox in then I'd say somebody used the FWD sandwich plate which only covers the top half and leaves the lower exposed.
If that is your issue its time to pull your gearbox out and put in the RWD sandwich plate.
I can supply a RWD sandwich plate if you need one.
Ahh ok. It's a big port from a fwd ae82 that's been put into the 86. So i would say you're right. How much for the sandwhich plate?
Hi
Have RWD plates also in stock
Pm if interested
Contact No: 0408998795
EMAIL: justjdmimports@bigpond.com
LINK TO MY WEBSITE FOR MORE PARTS & PICS http://www.justjdmimports.com
Link to My ride Thread http://www.ae86drivingclub.com.au/fo...y-Latest-Daily
