I’ve been doing a bit of searching and can’t seem to get a definitive answer on this. In theory everything should bolt in to my KE70 without any dramas. I know I’ll need to use the Celica LCAs and SA63 PS knuckles (same length as AE86, 125mm?). Will be converting to coilovers so spring perches etc aren’t a problem.
The issue I need to resolve is the effect on camber. A lot of people say that it will give horrible positive camber that can’t be dialled out with adjustable strut tops. Others say that it is fine.
I know that Cressida and MA61 struts definitely have this affect but I’ve read that the 4 cylinder 60 series Celicas (RA60, RA65, SA63 etc) run a different kingpin angle. It actually looks like some of the MA61 guys are using RA65 struts as an upgrade to give an extra 1.5° or so of negative camber.
From what I’ve read the MA61 and MX73 kingpin angle is around 10.5° and the AE86 / KE70 is about 8.5° so in theory the RA65 struts should have almost no affect on camber in a KE70? Can anyone shed some light on this? Are there any other problems I've missed here?
See below for some background:
