Results 1 to 10 of 53
Thread: Who's done FC/RX7 brake conversion
Threaded View
  1. #6
    Veteran Kid Karola's Avatar
    Karl
    S.A.
    Austria
    I have fitted the AJPS adapters, EG6 Civic discs, Series 6 FD calipers, braided lines and Motul RBF-600 fluid. IT's 200% better then the JDM slotted AE86 setup I used previously. Haven't fitted a larger MC yet, but have updated the proportioning valve to the latter 2 piece item. I'll probably fit a Willwood bias adjuster when I fit a 15/16 or 1" MC such as the R32 item mentioned to fine tune the brake balance.
    The over-hub is not necessarily a bad thing, with under-hub Civic discs I needed a 12mm slip on spacer to clear FD calipers with my neg offset SSR mesh and 6mm spacer to clear with 15x8.5 Equips I test fitted.
    Jazzy J's rotors being FC are 276x22 for those of you playing at home.
  1. Replies: 29
    Last Post: 28th September 2013, 11:25 PM
  2. FC RX7 BRAKE CALIPERS needed ASAP Sydney/Newcastle
    By ae86 drifter in forum Cars or Parts Wanted
    Last Post: 14th August 2012, 08:45 PM
  3. rx7 fc brake system for sale. - SA
    By parkertron in forum Car Parts For Sale
    Last Post: 10th April 2011, 03:16 PM
  4. RX7 FC brake upgrade
    By munki in forum Car Parts For Sale
    Last Post: 11th December 2009, 11:59 PM
  5. FC Brake Caliper Conversion
    By 70XIN in forum General Topics (No Technical Questions)
    Last Post: 25th February 2007, 10:21 AM
