Ask your questions here
Hey guys installing a ez wiring loom in my aw86 and making good progress but would like to speak to someone who maybe has done a complete custom harness install or had more exp just to bounce questions off.
Paying in beer for any one interested thanks in advance
My AE86 4AGZE to 3SGTE thread
Check out my sale threads for 4age and ae86 parts
http://www.ae86drivingclub.com.au/fo...nd-going-Turbo
http://www.ae86drivingclub.com.au/fo...ything-must-go
Sponsors
Platinum Automotive Smash Repairs - Padstow
Only really 1 so far. On the harness has a line for fuel pump with fuse but hooking up fuel pump to switch so thinking need to run relay to it for switch is that right or overkill?
Sponsors
The relay is what trips the fuel pump... And the relay is controlled by your ecu.
Last thing you want is to crash and have the fuel lines ruptured and fuel spat out everywhere.
Its to use more as a fuel kill switch so ill be wiring to relay anyways.
The car is running basic electronics.
Haltech ECU with INZ coils already wired all l really have to wire is
Fans
Fuel
F + R Lights
Blinkers
Brake Lights
Dash waring lights as using a IQ3 Racepack dash
Ignition
Not running Aircon so its a nice clean setup
Sponsors
Ahh yeah i get you... interupt it after the relay for your switch and you won't need a fuse on it.
Say you have the following order
Battery -> Fuse -> Relay -> Kill switch -> Pump
If there is an issue after the relay that causes excessive current draw (ie short to ground etc) it will blow the EFI fuse.
Ez-Wiring kit has that built in with relay should be easy enough to add that in
Sponsors
