Results 1 to 5 of 5
Thread: ST20V VVTi wiring Question - 2 wires?
    Mar 2011
    Ali
    Default ST20V VVTi wiring Question - 2 wires?
    Hi
    Long time listener, first time caller.
    Serioulsy, did search and can't see where this is covered.
    Wiring up me sedan, and stumbled on this...
    Bit of a grey area.
    ST20V VVTi actuator has 2 wires,
    Red and Black
    Which one does what?
    Its it as simple as it looks, a +ve and a -ve?
    How does stock ECU work the actuator,
    Is it -ve switched through the ECU for 1 position at certain rev, and returns by itself?
    Or does it switch reverse polarity to off position as well?
    If I follow what was already in place looking at what was there my simple brain tells me:
    Red = Aux Output on ECU
    Black = 12V power switched by 12V IGN
    I was going to wire Black to +ve 87 pin on relay, and red to -ve aux out put on Microtech.
    But before I go ahead, I would like some to pull me up if I'm wrong.
    Any help would be much appreciated.
    Thank you!
    Ali
    Don't think u need a relay as the ecu only provides the earth. On about 2k and off around 5k
    Mar 2011
    Ali
    Relay is for switched power supply only, not to trigger.
    This was wired to constant source, which I in my mind ain't right.
    Sorry, should be more clear;-
    Current wiring from previous owner is
    Black +ve
    Red -ve
    I would like to confirm that
    A> this is right, (common sense tells me normally its the other way around)
    And ask
    B> Been a while since I got into AUX output screen on Microtech, and I will have to double check, but from memory this LTX8 version I am using only has 1 (-ve) trigger point for on/off to set output.
    What potential issues can I cause from running VVTi advance all the way up to limiter?
    Ali
    If u don't have an answer i'll check it tomorrow for you on mine as to which pin on the plug has power.
    But look here
    Plug k is the one, and pin 1 with power. I know for certain the iscv power wire is black.
    If u run it up to the limiter u won't make as much power as the timing will be too far advanced... it gives u ~30 degrees of timing.
    Put it on ignition power as it was from factory and let the ecu earth it directly.
    Mar 2011
    Ali
    Thank you sooooo much for the info.
    I'm pretty sure you can set this thing for different switching on / off points points, however this is an older MTX8 model, its like almost 10 years old.
    My Bro has a Mircotech dash unit that will work with it, I'll lend it for the day and open up AUX output screen and play around with it.
    I'm sure I'll figure something out.
    Cheers,
    Ali
  1. Replies: 9
    Last Post: 5th November 2013, 08:28 AM
  2. Ke70 wiring question Help..
    By adds in forum Technical - Questions
    Last Post: 19th May 2012, 08:02 PM
  3. Yet another Alternator wiring question...
    By Andy San in forum Technical - Questions
    Last Post: 5th October 2011, 08:40 PM
  4. TRD inlet suit vvti or no vvti BEAMS
    By Celica RA45 in forum Car Parts For Sale
    Last Post: 29th May 2011, 04:33 PM
  5. 4ag wiring question?
    By trikzlane in forum Technical - Questions
    Last Post: 13th December 2009, 08:12 PM
