BUMP
BABY BLUE KE70 (SMURF)
ADELAIDE, SOUTH AUSTRALIA
Regretful sale, but just do not have the time to drive it any more.
Built from the ground up, rebuilt small port 4a with approximately 400km on it at a guess, barely run in, due to the cops giving me a defect within the first month on the road for height.
Chassis has had an unfortunate meeting with Mallala pit straight wall which has caused some front end passenger damage but has been pulled straight.
Perfect track car for the beginner lots of fun and all the fruit
In no rush to sell it, so please no low balls or time wasters. Price is firm due to the thousands I’ve spent on it and if I do not get what Im after ill part it out at a later date.
$6000 FIRM
JAMES 0439 030 556
ENGINE:
• AE92 4age 16v Small Port MAP (rebuilt)
• TRD Style Exhaust Manifold
• Cut & Shut Inlet Manifold
• KOYO Aluminum Radiator (custom mounts)
• Custom RWD Cooling System
• Trust Oil Cooler Kit (non-relocation)
• 2ltr. Custom Surge Tank
• Goss VL External Pump
• VL lift pump
• Few Speed Flow Fittings
• K&N Pod Filter
• 2¼” Straight Through
DRIVELINE:
• T50 Gearbox (ADM)
• One-Piece Braided Clutch Line
• AE86 Gearbox Cross Member
• AE71 Clutch Master & Slave Cylinder
• TRD Lightweight Flywheel
• Exedy Heavy Duty Clutch & Pressure Plate
• Custom One-Piece Tailshft
• Locked Standard Diff (Borgy)
SUSPENSION / BRAKES:
FRONT:
• AJPS AE86 Coilovers 8kg 200mm (plus T3 Camber Tops)
• KYB Excel-g Short Strokes
• AJPS Roll Center Adjusters 40mm
• AJPS Lock Spacer
• XT130 Corona Control Arms (fresh Super Pro bushes)
• AE86 Power Steering Arms
• AE86 Brakes (ADM)
• TRW AE86 Brake Pads
• Super Pro Steering Rack Bushes
REAR:
• AJPS 6KG 235mm Springs (cut to 200mm)
• AJPS on Car Adjustable Panhard Rod
• KYB Excel-G Short Stroke Uprated Dampers
EXTERIOR:
• Front & Rear Guards Rolled/Slightly Flared By Hand
• Blacked Out Light Surrounds
• Engine Bay Painted Pewter
INTERIOR:
• Nardi
• HKB Boss
• Cheap Ball Gear Knob
• Fully Striped
• Floor Painted Gloss White
• Fixed Bucket Seat (but seat mount is broken will supply stock seat or Bride Brix for extra $$$)
• Fire Extinguisher
• AE71 Pedal Box
• Custom Dash
• Speco Tacho
• Speco Oil Pressure Gauge
• Speco Oil Temperature Gauge
• Speco Water Temperature Gauge
• Speco Fuel Level Gauge
• Custom Ignition Switch Panel
• Battery Isolator Switch
WHEELS:
• Pair of SSR Longchamps XR4 15” x 7” -1 (+PLUS 4-6 40% tires)
• Pair of MA61 14” x 7” +8
$6000 FIRM
JAMES 0439 030 556
BUMP
Being parted out.
Delete please Jacob
