ok ill go with the 86 stuff where can i find it all? i just look up BC 86 coil overs?
BTW what about break upgrades? planning on putting 3sge in her or a sr unsure yet
Cheers mate
Cheers mate
Cheers mate
Dont use AE86 stuff, too small stub axle and brakes. Find RA65 struts and brakes, they are 258mm rotors and vented. Speak to AJPS on the forums here
ok, i dont get this? why are you swapping out your front suspension?
keep the front struts stock, get a weld on coilover kit and new inserts, AGX or something and a set of camber plates.
thats that sorted.
if you want bigger brakes, you can do the BA falcon and R33 conversion, just re drill the rotors to 4 x114 and bolt it all up.
might need to go to pirtek to get a new line from the strut to the calliper, so check that.
not sure about LCA option
im sure someone else can suggest one. or i can sell you a DIY adjustable LCA kit that you can weld on.
You can use MX73 RCA's
then you just need to sort cator rods and steering knuckles.
maybe someone else can suggest some options for this?
PS ive actually got a set of ST141 stuts modded with coilover kit, 8kg with helpers, kyb AGX 4 way adj shocks, and BA/R33 brake conversion, and MX73 RCAS if you go down that road.
^^Should buy those mate. Does the R33 calliper bolt to the stock mount Sundee? Does the BA rotor increase track? Thanks.
hi mate, i replied to your pm
It's pretty much the same strut as mx73.
Calliper bolts straight up, rotor gives you 6 - 8 mm track per side from memory (the thickness of the hat mounting plate)
I'll take some pics and upload.
hey buddy what price do u want for them????
here is the full spec:
St141 strut/hub shortened.
HSD 8kg coilover kit with helper springs
KYB AGX short strokes 4 way adjustable
R33 Gtst 4 pots
DBA BA falcon rotor re drilled to 4 x 114.3 (as new)
QFM A1RM pads
custom hi tensile rotor spacer ring
T3 ae86 Camber plates
T3 upper hat system.
new wheel studs.
all parts were brand new, setup was in one of my e7's which only ran a few hrs ( no track work) then was parted out.
Parts would cost you $1800 - $1900 to buy new and thats not assembled or modified.
Make an offer man.
here are pics
also got these 86 PS knuckles that fit the mx strut
