Results 1 to 4 of 4
Thread: sc14 supercharger cleaning
    Dec 2013
    brandon
    nsw
    northen rivers
    Default sc14 supercharger cleaning
    hi i im new to the forums ive owned this ke70 csx for a little while now and at the moment im putting a toyota 3tc and gearbox in it.
    Today i purchased a sc14 supercharger pretty cheap and ive noticed the rotors are dirty from someone not runniig a air filter so first of all does a sc14 have teflon coating and what can i clean the rotors with if so? kerosine, brake cleaner etc any help with more info on a sc14 would be great ive looked this all up on google and having no luck.
    Mt Macedon
    Yes, the SC14 has a Teflon coating on the rotors. You can basically clean it with whatever you like.
    What do you want to know about the SC? It pumps 1.4 litres of air per revolution and is pretty simple. To work out drive ratios you can base it on a 4AGZE, your motor is slightly bigger, but being single cam will probably flow slightly less, and you should end up in the ballpark. I seem to remember 3Ts run V-belts only, so sorting out a pulley and belt for the SC may require some work.
    Dec 2013
    brandon
    nsw
    northen rivers
    thanks mate! yeah the v belt setup can be replaced with a 4age harmonic balancer with a 22mm spacer, same with alternator just gotta work out the water pump pulley aswell i wanted to know more about sc14s regarding factory boost on the 1ggze because i want to run 4-5psi with my stock motor so i need a smaller pulley but have no idea what diameter the stock 1ggze pulley is to work to work out a smaller pulley
    Mar 2011
    Ali
    There is good info on Toymods, look for posts from user name Terra Operative - Jarred.
  1. Sc14 Supercharger
    By pigke70 in forum Car Parts For Sale
    Last Post: 14th February 2011, 05:35 PM
  2. rebuilt sc14 supercharger (sa)
    By keseventy in forum Car Parts For Sale
    Last Post: 5th February 2010, 10:43 PM
  3. SC12/SC14 supercharger
    By harvo in forum Cars or Parts Wanted
    Last Post: 24th August 2009, 09:15 PM
  4. toyota sc14 supercharger (rebuilt)
    Last Post: 13th May 2009, 05:04 PM
  5. wtb sc14 supercharger
    By team d - dori 86 in forum Cars or Parts Wanted
    Last Post: 30th April 2007, 07:31 PM
