Results 1 to 9 of 9
Thread: GOLDMEMBER--Does my wagon make you horny baby? does it?
    Dec 2013
    luca
    tasmania
    launceston
    Default GOLDMEMBER--Does my wagon make you horny baby? does it?
    After many months of searching I've finally found my first car...
    a 82 ke70 wagon with a blown headgasket, leaking rear drum, no handbrake cable and a couple of little dings in the bodywork but it has hardly any rust in it.
    The guy who owned it had it stored out the back of a workshop and my dad saw it there when he went there to drop something off, I picked it up the next day for $750 with 6 months rego.
    About two days later I saw a add on gumtree for a 84 corolla wagon with no pictures, I organised to have a look at it that day and got it for $200 with the only things wrong with it being badly banged up on the rear left arch area and a leaking drum aswell. I then switched the good parts from the slant front into the flat front, the seats, rear lenses, hatch dampers. etc
    UPDATE!
    Driveline
    -4k
    -k50
    -no egr rubbish
    -advanced timing :p
    Suspension/brakes
    Front
    -8kg ajps coilovers
    -kyb excel g ss shocks
    -adm ae86 brakes
    -xt130 lca's
    -power steering arms
    -lock spacer
    -40mm rca's
    -techno toy tuning camber tops with needle bearing upper
    -newish brake pads and lines
    -caster arms wound out
    -various nolathane bushes
    -no swaybar
    Rear
    -sierra shocks
    -reset leaves with an extra leaf added
    -1 inch lowering blocks
    -new bushes
    -cut down bump stops
    -welded diff (which sucks)
    -new brake shoes
    Wheels and tyres
    -13x7 hotwires
    -cheap shitty tyres
    exterior
    -no roof racks anymore
    -removed rear bumper and tow ball etc.
    -all inner lips flared
    -mud guards removed
    -no spare tyre
    -taillights off red wagon
    Interior
    -370mm momo monte carlo without thumb indents
    -techno toy tuning steering wheel spacer
    -saas fixed back seat
    -tacho dash
    -a random gear knob
    -handbrake button
    -good passenger seats out of red wagon
    Plans
    -put original diff back in
    -add a rear swaybar
    -better tyres
    -install 4age
ID:	31121   Click image for larger version.
ID:	31122   Click image for larger version.
ID:	31123   Click image for larger version.
ID:	31124   Click image for larger version.
    Veteran drift kid's Avatar
    Glossodia
    Lools good, with the coil overs it's all about budget and experience, if you don't have much to spend, keep it simple and and a sleeve kit on your struts, if you have a bit more cash and want something nice get some aftermarket coils *cough* shockworks *cough*
    Dec 2013
    luca
    tasmania
    launceston
    is it just my computer or are all the images I put up really small? and thanks for the reply drift kid, I think I will end up with a sleeve kit, what struts should I be looking at getting to make into coilovers?
    Good purchase.
    Putting the 4age in , the quickest / simplest way is to buy mounts off jordo that bolt the 4age into the ke70 xmember, buy a gearbox xmember off the ae71.
    You'll need the hydraulic peddle box too, which can be modified by the same guy above or buy an ae71 one. Clutch master / slave is available from AJPS cheap.
    After that you have to tackle the wiring, which is confusing at first but not overly difficult. I might have some exchange looms available in a few weeks and I have a couple of FWD cut n shut manifolds too.
    Being a wagon, i'm not 100% sure on the tailshaft choice
    Dec 2013
    luca
    tasmania
    launceston
    cheers for the info and the link matt, ill defiantly look into that when the time comes
    also is there any difference between adm and jdm a86 struts? as a pair of bare 86 struts have come up for sale locally for under $90 and im considering getting them to turn into coilovers?
    Eddie
    They are identical aside from brakes.
    Veteran stahlz_ae86's Avatar
    Paul
    Price is about right for struts, expect to pay 200 for hubs though. Better off starting with RA40 or XT130 for price, stub axle size and brakes.
    Dec 2013
    luca
    tasmania
    launceston
    Well its been a long time between posts and im hoping to update this more frequently as I progress.
    ive sold the red wagon on and bought all the usual ke70 bits as you can see in the updated first post, ive also bought a manual ae71 and twincam ae82 so will hopefully be doing the conversion pretty soon.
ID:	33354   Click image for larger version.
ID:	33355   Click image for larger version.
ID:	33356   Click image for larger version.
ID:	33357   Click image for larger version.
    Dec 2013
    luca
    tasmania
    launceston
    More photos.
ID:	33365   Click image for larger version.
ID:	33366   Click image for larger version.
ID:	33367   Click image for larger version.
ID:	33368   Click image for larger version.
  1. Me so HORNY!
    By rallystanza in forum Car Parts For Sale
    Last Post: 22nd February 2013, 01:59 AM
  2. 16x7 +18 jdm tri spoke 5x114.3 cheap cheap you horny buy now
    By stx-16 in forum Car Parts For Sale
    Last Post: 29th November 2011, 12:36 PM
  3. 4AGE Baby!
    By KENut in forum Car Parts For Sale
    Last Post: 2nd November 2010, 02:15 PM
  4. HELP MY BABY
    By 4AC power in forum Technical - Questions
    Last Post: 26th June 2006, 03:28 AM
Tags for this Thread
