Results 1 to 3 of 3
Thread: Heavy shudder under heavy braking with s13 turbo setup.
    Senior Member Mad RS's Avatar
    Queensland
    Wynnum
    Default Heavy shudder under heavy braking with s13 turbo setup.
    Hey Guys,
    I have noticed that I have a heavy shudder under braking. I decided to pull the front brakes apart and inspect. Everything seems to be fine until I researched replacing the discs. I was told that the front brake setup is s13 turbo. I took some measurements and nothing matches. My discs are 259-260mm in diameter, 25mm thick (vented) with a 57mm hat height and my callipers have markings of "24 (Nissan Symbol in the middle) then 566 L or 575 R". None of these numbers match any Nissan disc rotor that I can find.
    Does anyone know what I have?? The numbers should be fairly close as the brake rotors and pads look new.
    Run what ya brung...............and make damn sure ya brung enough!!!!
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    Most likely the discs have gotten hot and warped, just get them machined. Unless you have a wheel bearing issue also?
    A dial gauge to measure run out but if they are thick enough just get the rotors machined
  1. heavy steering
    By ae86 in forum Technical - Questions
    Last Post: 16th December 2010, 12:35 AM
  2. pbr heavy duty clutch how do they compare to excedy heavy duty?
    By kerola in forum Technical - Questions
    Last Post: 7th August 2010, 10:19 AM
  3. heavy steering
    By ae86ln in forum Technical - Questions
    Last Post: 17th April 2010, 11:37 AM
  4. Heavy Machinery
    By Nicko in forum Youtube Chan
    Last Post: 11th April 2010, 11:46 PM
  5. heavy steering
    By redsprinter in forum Technical - Questions
    Last Post: 20th November 2009, 09:18 PM
