Results 1 to 2 of 2
Thread: Blowing 90amp fuse at battery terminal
    Aug 2013
    Matty
    Default Blowing 90amp fuse at battery terminal
    Hi all,
    I have just finished my 4AC to 4AGE conversion,
    Car runs good and the alternator charges, I did the alt wiring as per golbergs guide, but today I noticed I had lost power to the "on" and "accessory" power, I wriggled the battery terminal and power came back on, the power went off again and it turned out to be the 90amp fuse on the battery terminal.
    I haven't looked into the wiring yet but thought I might ask if anyone knew what the fuse was or why it blew, is it possible that the fuse amp needs to be upgraded as the 4age alternator is higher output than the 4ac one??
    For that fuse to blow you must have a direct short / power to ground or something arching. Your alternator output isn't that high.
  1. EFI Fuse Keeps Blowing! Help!
    By Robo86 in forum Technical - Questions
    Last Post: 3rd November 2009, 08:59 PM
  2. fuse keeps blowing
    By sprint86 in forum Technical - Questions
    Last Post: 11th April 2009, 09:58 PM
  3. Front wiper motor keeps blowing a FUSE
    By Wanabe_Garage in forum Technical - Questions
    Last Post: 20th December 2007, 04:32 PM
  4. corona blowing light fuse
    By benny - ra60 in forum General Topics (No Technical Questions)
    Last Post: 25th June 2007, 12:12 PM
  5. Fuse problem after moving Battery to boot...........
    By DRFT - 86 in forum Technical - Questions
    Last Post: 18th January 2007, 05:31 PM
