Thanks for the kind words Geoff
I can definitely help
let me know what you need
^ RA40 struts and hubs off that car, perfect base to start from. If the seller has realistic prices you should be able to have them to your door for less than 300 all up including brakes. RA40 have removable brake caliper brackets like AE86, only on a bigger stub axle (same angle). We are running them in my bro's AE86 with Citroen Xantia 283x22mm discs and FC calipers with a 15/16 Navara master. So that gives you an idea they are pretty limitless.
What coil over kits do you guys do for ke70's and are they front and rear coilover kits
Thanks
you will need ae86 struts, and all the parts that suit and then bolt that into your ke70
i have one pair of struts left if interested
pm me
Pm'd
