Results 11 to 20 of 23
Thread: KE70 4 link Arm options
  1. #11
    Gone
    Joel
    Picton
    If your go equal length use rose joints.
    Ps - I would be leaving the lower arms stock (these set your wheel base) and run adj upper arms to correct the pinion angle.
  2. #12
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    Definitely use rose joints if you go equal length, and different bolt positions on the boxes so you can play around with squat and anti-squat by changing the arm angles.
  3. #13
    Veteran drift kid's Avatar
    Glossodia
    To be honest I don't agree with that, urethane bushes are perfectly fine, they are stiffer than a stock rubber bush but not as harsh and damaging as a rose joint, yes it is a track car but why make something harsh and unenjoyable when it isn't nessiscary, I really enjoy the comfort that my car has on the track
  4. #14
    Gone
    Joel
    Picton
    If its got a gutted interior, then having rose joints (increasing NHV or NVH) will be neither here not there.
    it does increase the road transmitted noises, but, you have a helmet on... it doesnt add clunking or anything link that... its more like just turning up the ambient noise.
    the rose joint gives you the most direct link between the driver and the road.
    ive ran them in street cars and it hardy makes a difference in noise, but maybe im just deaf..
    thats why serious race cars run nothing else..
  5. #15
    Glossodia
    I'm not talking about noise, I'm talking about bumps and shudders from driving over rough surfaces/undesirable objects etc, it transfers the abuse straight into the chassis stretching bolt holes and cracking welds etc, high end motorsports can afford a new chassis etc, I would like to make my car last as long as I can
  6. #16
    Hair model Jacobxxx's Avatar
    Jacob
    Sunshine Coast
    I plan on crashing mine before it wears out.
  7. #17
    Gone
    Joel
    Picton
    Right on man! Hahah
  8. #18
    Mar 2011
    Mt Dandenong
    With an equal length setup there shouldn't be any massive load on the arms or mounts though, as they are there to pivot only and there's no bind or twist acting on them either. The shocks and springs would take almost all of the force from road imperfections.
  9. #19
    Gone
    Joel
    Picton
    you would get pulling when you yanked the old handbrake and some push when you kicked the clutch... but really.....
    F it, just run them in an equal length, happy dayz haha
  10. #20
    Glossodia
    There is definitely much load on these, that is what these arms do, they are designed to stop the diff from moving forwards and backwards and at the same time they allow it to move up/down, I don't see how a shock is going to stop the load of the rear wheels hitting a sudden incline (ripple strip edge) the forces will be transferred straight through the arms, through the rose joints and into the holes/brackets/welds that the arms are bolted to, I am not saying that rose joints are stupud or a bad idea, I am just saying that there is much that is overlooked when people do this sort of modification
  1. Brand new Super-Pro 4 link/trailing arm bushes
    By jet111 in forum Car Parts For Sale
    Last Post: 1st September 2010, 07:27 PM
  2. Trailing arm bush options
    By starni_boy in forum Technical - Questions
    Last Post: 5th April 2010, 01:44 PM
  3. AE86 trailing arm/4-link .. yep, just one, any one
    By 70XIN in forum Cars or Parts Wanted
    Last Post: 11th March 2010, 06:43 PM
  4. Engine Build - Valve Options - Bearing Options - Head Gasket
    By hitoriko in forum Technical - Questions
    Last Post: 19th September 2009, 05:59 PM
  5. AE86 <-> Ke70 door arm rest
    By li21 in forum General Topics (No Technical Questions)
    Last Post: 19th February 2007, 01:13 PM
Tags for this Thread
