Results 11 to 12 of 12
Thread: T50 Rebuild Kits - Who wants one?
Threaded View
    Mar 2014
    Will
    nsw
    sydney
    Aust.
    Default T50 Rebuild Kits
    Hi guys,
    The kits are available.
    Contents:
    Bearing - 1x Front - Input shaft bearing
    Bearing - 1x Rear - Output shaft bearing
    Bearing - 1x Centre - Output shaft bearing
    Bearing - 1x Front - Layshaft bearing
    Bearing - 1x Centre - Layshaft bearing
    Bearing - 1x Rear - Layshaft bearing
    Bearing - 12x Needle roller bearings (uncaged "jelly bean" rollers) - Serves as idler needle bearings for 4th gear
    Bearing - 4 x Caged needle rollers - Serves as idler needle bearings for reverse, 1st and 2nd gear
    Bearing - 1x Split cage needle roller - serves as idler needle bearings for 5th gear
    Consumable - 5x Synchros - synchro for each gear, reverse has no synchro
    Consumable - 2x Oil seals (Front input shaft & Rear output shaft)
    Consumable - 1x Special - Bronze shifter bushing
    Consumable - 1x Shifter pivot seat washer
    Consumable - 1x Shifter pivot seat bushing
    This is a comprehensive kit, it also includes the caged needle bearings which have been custom manufactured for this batch. Every bearing, oil seal, synchro and bushing is included. The paper gasket kit is omitted as they are prone to leaking. Permatex RTV silicone does a much better job.
    Price: ($480) + $15 Australia wide tracked shipping. Shipping is extra for those outside of Australia (yes that includes you Kiwi's)
    I will split kits, if you have a partial T50 kit or missing T50 bearings etc. let me know and I will omit parts and put together a custom kit for you.
    Drop me an email , PM's don't work for me here.
    Cheers,
    William
  1. wtb T50 rebuild kits
    By joe in forum Cars or Parts Wanted
    Last Post: 3rd June 2008, 05:11 PM
  2. T-50 gearbox rebuild kits
    By 4AGE - 86 in forum Technical - Questions
    Last Post: 6th November 2007, 09:46 AM
Tags for this Thread
