Results 1 to 3 of 3
Thread: Swap Altezza/Progres'/Brevis 2 pot rear calipers on AE86/KE70
    Senior Member qagzie's Avatar
    Aug 2013
    Maxwell
    Drift Zone
    Palm Village
    Uganda
    Default Swap Altezza/Progres'/Brevis 2 pot rear calipers on AE86/KE70
    Hellos,
    Just wanted to know if anyone has used 2Pot rear calipers off the Altezza/Progres/Brevis on their ae86 or Ke70.
    I'm doing the famous 4 pot FC RX7 swap at the front (KE70) so I'd like to use 2 pots on the rear to make the ratio 2:1...
    Any ideas?
    Moderator Sam-Q's Avatar
    Endeavour Hills
    When you say matched you can do the same by having single pistons on the back, so long as the cross sectional area is right. It can happen that a single larger piston uses more fluid than two smaller ones.
    Aug 2013
    Maxwell
    Drift Zone
    Palm Village
    Uganda
    Thanks for the idea... Well, the pistons in the altezza rear 2pots are 35mm in diameter, which are really close to a 2:1 ratio with the 36mm rx7 4 pots... That's why I thought they'd be a viable option. Do you know of any single piston rear caliper with similar specs?
  1. {vic} ae86 rear calipers
    By dove grey 64 in forum Car Parts For Sale
    Last Post: 18th March 2013, 07:25 PM
  2. Replies: 9
    Last Post: 8th September 2010, 08:04 PM
  3. Replies: 2
    Last Post: 4th September 2010, 08:07 PM
  4. Ae86 rear calipers with brackets and backing plates
    By cando1 in forum Cars or Parts Wanted
    Last Post: 23rd May 2008, 06:28 PM
  5. pot pot pot pot panda ae86
    By hfae86 in forum AE86 Owners Forums
    Last Post: 4th March 2008, 05:09 PM
