Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Thread: ae86 diff help help help locked diffs suck
  1. #11
    Aug 2010
    Geoff
    mt dandenong
    OP, If your diff takes 5k rpm to move then loosen off the pinion nut.
    Solved. But yes welded centers are not good for anything other then paddock bashing
  2. #12
    Mt Macedon
    If it is hard to take off then the diff is welded wrong. Possibly got spatter on the crown/pinion (cue photo from 4WD forum of "welded diff" with crown fully welded to pinion).
    For cheap you can get a new centre and weld it properly (though S series centres are a pain to weld) or you can pay the piper and get a T series LSD.
    But to reiterate, the symptoms you list aren't typical of a welded diff.
  3. #13
    Mar 2011
    Ali
    Having to rev to 5 grand is not right.
    Something screwy goin on there.
    Series 1 drum brake T18 Zenki T series can be bough cheaply enough, if you are patient they do pop up.
    Not all Toyota forums want the kind of money you see them on here for.
    A new 2 way LSD center with no crown or pinion will set you back ~1000 new (give or take ~200 either way)
    Tailshaft needs to be considered also. This can vary depending on what gear box you want to use.
    Either way 1-2K is a fair estimate for a set up.
    If you don't want to spend this sort or coin, a spooled S series is a viable option if welding is considered to geto for you.
    or welded side gears, but done with some care.
    are some options
  4. #14
    Noooob
    Could be something as simple as your handbrake locking on
  5. #15
    Veteran drift kid's Avatar
    Glossodia
    I was going to say binding brakes. My s series welded diff was amazing, too many people bad mouth weldies, I loved it and daylied it for a while
  6. #16
    Mt Macedon
    ^^ Agreed. I've had a daily with a locked diff for probably about 5 years all up. They are cheap, cheerful and fun.
  1. Replies: 2
    Last Post: 15th December 2013, 09:24 PM
  2. WTB: AE86 Locked Diff Centre
    By domenicbasso in forum Cars or Parts Wanted
    Last Post: 11th August 2013, 05:43 PM
  3. Replies: 2
    Last Post: 15th February 2013, 11:30 PM
  4. Replies: 2
    Last Post: 30th September 2011, 04:35 PM
  5. S-diff locked
    By FullMetal in forum Car Parts For Sale
    Last Post: 29th May 2007, 04:47 PM
Tags for this Thread
