My workshop clean up continues
I have a Blacktop Bottom end that has been freshened up,
light hone and new rings
new main and rod bearings
new ARP rod bolts.
chemial clean
oil up serviced
Professionally assembled
$ 800
16v ARP head bolt set, opened but never used.
$100
Silver top head, that has had some mild port and combustion chamber work. It has been cleaned, valve seats cut, and is assembled with valves , springs and cam buckets. I will assemble with your choice of cams and VVt unit (BT or ST cams ) and shim the tappets. $900 or $1200 with a matching manifold and set of ST throttle bodies, fitted wit 75mm Sam-Q trumpets.
