Results 1 to 10 of 16
Thread: Starting 4AGE Bigport for the first time in a while...
    Site Supporter Driftspec's Avatar
    Keating
    Caboolture
    Default Starting 4AGE Bigport for the first time in a while...
    Hi all, long time no see!
    Sadly the AE86 of mine doesn't get much of a run these days as I have a proper daily for the 100KM daily trek to and from work. Last time it had a drive was about 6-7 months ago when it did such a drive. Only problem I noticed was it wasn't charging properly, but I'm putting that down to a bad battery.
    Long story short, its time to fire her up again. Will get my hands on a new battery, but what else do I need to start it up again? I at least want to turn it over before taking to to a trusted mechanic for fluid change and look over.
    Am am prepared to throw octane boost/injector cleaner into it but what else do I need to do?
    4AGE is here! Cheers 44GTE and Anthony for your help! http://www.ae86drivingclub.com.au/fo...ad.php?t=10384
    AE86 Driving Club Official Rules -please read!
    What am I doing right now? Twitter me!
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    I would put a small squirt of oil down each of the spark plug holes so the rings don't lock up, and generally when storing engines for long periods of time it's best to take the cams out so all the valves are closed and massively overfill them with oil. Stops the bores and rings rusting.
    Noooob
    6-7 months isn't long
    Senior Member Dylan's Avatar
    Dylan
    Shouldn't need to do anything else
    Keating
    Caboolture
    Sweet, my only thought is stale fuel but popping some injector cleaner in and letting it prime itself should be ok yeah?
    Joel
    sticks
    If you need a "trusted mechanic" to do a fluid change you should buy a Hyundai I30 or something.
    Rings are unlikely to be rusted after 6 months unless it had a blown head gasket before it was parked up. Squirting some oil in each cylinder is not a bad idea though because it will improve ring seal and make it easier to start. I use a 5:1 mixture of unleaded and 2 stroke oil. 2 stroke oil is good because it burns cleanly and won't foul the plugs. It's also a good idea to do this before leaving the engine sit for a long time.
    If fuel sits for a while the light fractions/volatiles/good stuff evaporates. Add something with some octane booster in it. Also check the oil on the dipstick to make sure it isn't too thick/sludgy. Don't try to start it on a cold morning. Disconnect the coil then crank the engine until the oil pressure gauge starts to move, then reconnect the coil and start the engine.
    Keating
    Caboolture
    Technically I'm also a Prius driver nowadays... Can do a fluid change myself but a) don't have the time and b) there's a bunch of other stuff that needs to happen with the car anyway so happy for someone else to tackle it.
    Excellent, thanks - that's good advice. Was going to try and get stuck in before it gets too cool up here. Will try this weekend!
    Keating
    Caboolture
    Alright...
    Good news: topped up oil last weekend, car turns over and has oil pressure!
    Bad news: engine fires for a few seconds and stops. After a lot of checking it seems the fuel pump is toast. I've been doing some reading and dropping the fuel tank shouldn't be too hard (not much fuel on it) but the question is, has anyone bought an OEM replacement from Repco or similar? Or am I better to get a pump from another model? Google hasn't helped me much here.
    Jun 2011
    james
    oxford
    general area
    England
    Have you flushed the old fuel out ?
    If not you might want to try flushing out the old fuel (easiest but not the safest way is by taking off the fuel feed at the fuel rail, ignition on and dumping the fuel into a can) otherwise I think there is a drain on the fuel tank.
    Fresh fuel and try that.
    Aug 2010
    Geoff
    mt dandenong
    Depends on what fuel tank you have. Injected or carb tank
  1. adm 4age sprinter starting bid 3500 vic !!!!
    By shammy in forum Ebay Items - My Stuff
    Last Post: 9th December 2013, 08:35 PM
  2. 4age starting issue
    By markKE70 in forum Technical - Questions
    Last Post: 12th January 2010, 10:38 PM
  3. Where to source a 4AGE when the time is right?
    By TTZ32 driver in forum General Topics (No Technical Questions)
    Last Post: 9th April 2007, 04:44 AM
  4. 4age starting prob
    By sprinter86 in forum Technical - Questions
    Last Post: 8th July 2006, 04:44 PM
