For sale 4age 16v bigport rear wheel drive engine package.
Engine is already converted to RWD, with manifold cut and shut, RWD alternator bracket, engine mounts. Engine still turns over, was removed from car about two months ago. Needs new injector seals.
T50 gearbox with mount, bit rusty, short shifter and standard shifter included.
Clutch master and slave with lines.
Jap ECU (89661-12150), ADM ECU (89661-12250) and cut loom (still has all the plugs).
VL lift and high pressure fuel pump.
AE86 crossmember and steering rack with tie rod ends.
RWD exhaust manifold and straight through 2 inch exhaust.
Ae86 radiator with twin thermo fans.
Oil cooler – engine has sandwich plate on oil filter housing for feed and return in sump.
Exedy HD clutch – barely worn in, less than 500km on it.
Ae71 pedal box – lots of surface rust.
$600 for the lot, may separate.
Located in Inman Valley, near Victor Harbor.
Please call or text message me on 0433070281. Thanks.
