Im looking into brake upgrades at the moment and im wondering if anyone knows exactly what the difference is between the front hubs on the 72 vs 86, according to all parts references i can find the ae86 and te72 both use the same front wheel bearings so obviously the stub axle is the same, i know calipers and discs all differ from 72, 86 adm and 86 jdm, the bolt pattern on the stub axle for the caliper brackets appear the same, there seems to be a bit of conflicting info re te72's on the net, btw im planning to use fc rx7 calipers
Pretty sure series 2 T18 (TE72) struts and brakes are same as ADM AE86. Early T18 different though.
