Results 1 to 7 of 7
Thread: KYB AGX Camaro Shocks with AJPS Springs - Not Captive
    Aug 2013
    Graham
    Default KYB AGX Camaro Shocks with AJPS Springs - Not Captive
    I’ve fitted KYB AGX Camaro shocks and uncut AJPS 4.5kg springs to the rear of my KE70 and found that the springs are a good inch or so from being captive at full droop. Car needs to pass a RWC and I wouldn’t be happy with non-captive springs anyway. This is what I was considering:
    Any feedback or alternative suggestions would be appreciated.
    Veteran anastasios's Avatar
    Taz
    Earlwood
    how many times are you going to be totally airborne?
    do you have the rubber gaskets that sit on top and below the spring?
    Aug 2013
    Graham
    Yeah even with the isolators it's still a fair way off being captive. I realise it's not likely that they're going to fall out but I'm just not cool with the idea of them sitting loose in there. Also, I need them captive for a RWC.
    Site Supporter Javal's Avatar
    Josho
    Have the shock mount on the diff moved down 25mm. I've had mine moved down 40mm+ to keep mine almost captive at full droop - as in they're never coming out, but there's still 10mm freedom of movement. Not enough for the spring to move over the lip on the lower spring platform. I still need a 10-15mm poly spacer (where the fuck can I get these?) to keep it firmly in place, so says the engineer.
    Aug 2013
    Graham
    Energy Suspension makes them for the AE86, pretty sure they're around 10-15mm. Also pretty easy to find elsewhere online. There's a place here is Brissy called Auto and Marine Urethane which does the thicker 4x4 spacers.
    Also, what spring / shock combo are you running? My 1" gap was just a rough estimate.
    Veteran AJPS's Avatar
    Lonsdale
    i can supply 3.5kg springs which are are about 20mm longer
    car will sit a little bit higher
    Josho
    Good question, i've got 3.5kg/mm springs, fuck knows what freeheight as they've been re-set about three times. Estimated to be about 280mm free. KYB excel-G short strokes in the back. My car is not an xE7x / AE86 though so it's probably a bit different. Relocated shock mounts are a good way to do it as you keep your ride height but actually set your shock in a good position.
  1. AJPS springs, RCA's, KYB Excel-G lowered shocks
    By Wilson in forum Car Parts For Sale
    Last Post: 11th October 2010, 07:00 PM
  2. FS: [SYD] Brand new KYB shocks and AJPS springs
    By willio in forum Car Parts For Sale
    Last Post: 16th July 2010, 12:22 AM
  3. KYB AGX short stroke shocks
    By shawn_26 in forum General Topics (No Technical Questions)
    Last Post: 14th March 2010, 11:10 PM
  4. For Sale: 8kg AJPS springs and Sierra KYB shocks
    By adam in forum Car Parts For Sale
    Last Post: 11th February 2009, 07:39 PM
  5. kyb agx shocks
    By ae86 in forum Technical - Questions
    Last Post: 7th January 2009, 11:34 PM
