Results 1 to 5 of 5
Thread: [VIC] AE86 and 4AGE 20&16 parts
    Dec 2012
    Avi
    East
    Default [VIC] AE86 and 4AGE 20&16 parts
    1. AE86 ADM Hubs and brakes, available as soon as I get motivated $220
    2. 4AC Complete air-conditioning system. radiator + lines + compressor + plug, great condition = offers?
    3. 4AC Bosch timing belt brand new in box $15 or something..
    4. 20v Silvertop flywheel, good surface plenty of meat left $80 ono
    5. 4age brand new never run RWD stainless steel 'shorties'. 4 into 1 design based on a pulsar sss turbo extractor, circular 2 1/4" (i think, or bigger) outlet not square, very nice smooth collector with new multi-fit flange (16v and 20v) nicely welded and de-burred, good for top end revs $170 ono
    For use with oil filter relocation kit or oil cooler adapter etc, stock 20v filter comes too close to the extractors, from memory I think it would foul on the filter.
ID:	31469Click image for larger version.
    6. Unique CNC machined 20v Thermo-housing, nice big thermostat design, internal bleed, 3 tapped sensor threads for 20v, 2 tapped heater threads. Just needs bottom plate and end plate over thermostat cut to size and attached to finish off. Tapped into an end plate (you make) covering the thermostat is the cold water inlet, usual hot outlet from original 20v location next to #4 piston exhaust side. Not too hard for a handy dude. This takes care of all the cooling, thermo and heating nicely hidden away at the back of a 20v head, and uses the original cooling path that toyota designed for the 20v. Cold inlet thru head/throttles first, out from block exhaust side. Might need to fit a gearbox spacer to get a little hand space at the back there if you want it. Also need some cooling pipes to run from rad to back of block, whatever is available really, but copper is cool. Cost a fortune to design and mill, never got round to finishing it off, possibly the cleanest solution I can think of besides from having cooling pipes in the bay - Will look alright anyways. $250 onoClick image for larger version.
ID:	31466Click image for larger version.
ID:	31463Click image for larger version.
ID:	31464Click image for larger version.
    7. HKS Mushroom Filter, reusable washable type, 6 months use, suit 16v $100 ono
    8. Tomei Fuel Pressure Regulator
    with a few spanner marks, perfect working order, fitted once for 5mins to diagnose, $80
    9. Toyota Genuine Oxygen Sensor, used for 5 min, tiny scuff marks on the plug from driving around the block, perfect working order. $100
    Jan 2013
    Paul
    Does the tomei regulator come with a guage?
    Is it adjustable tomei type s?
    Dec 2012
    Avi
    East
    Yes adjustable with black guage
    Apr 2010
    wagga wagga
    PM sent regarding hubs and brakes, cheers.
    Dec 2012
    Avi
    East
    PM's replied. Also got:
    Near New Toyota genuine oxygen sensor, fitted and ran it for 5mins, bit of a graze on the plug when I went round the block, then removed cause I went Haltech. $100
  1. [VIC] ROH Milano & near new tyres, 4x114.3, 16x8 +20 & 16x9 +20 $1200ono
    By itstok in forum Car Parts For Sale - Wheels
    Last Post: 5th May 2013, 11:20 PM
  2. VIC: 'Fabulous' 19x10.5j +16 and 9.5j +20 VIP Wheels
    By Sprinter86 in forum Car Parts For Sale - Wheels
    Last Post: 4th March 2013, 09:45 AM
  3. Replies: 12
    Last Post: 18th October 2012, 04:31 PM
  4. [VIC] S14 SR20DET & Watanabes 16 & Various S chassis parts
    By nGtim in forum Car Parts For Sale
    Last Post: 1st September 2012, 08:11 PM
  5. Replies: 1
    Last Post: 13th April 2011, 08:16 PM
